Results 1 to 8 of 8
    Non-member andybond's Avatar
    Oct 2009
    Doncaster
    Helix SMF kit.
    Its on my car. The clutch is fractionally heavier but nothing like as heavy as a five with a paddle.
    Went for the organic setup and lightened flywheel. The standard one weights a tonne ( metaphorically ) and the lightened one must be 50% lighter. I didnt weight it when being fitted.
    Re: Helix SMF kit.
    Andy.
    any pics? I looked at the helix kit ages ago but for £1200 notes and only 340ft/lb?? It was a hard one to . swallow
    Oct 2009
    Doncaster
    Re: Helix SMF kit.
    I only have pics of it fitted.
    It wasnt as expensive as that Matt for all the kit. It wasn't £1300 fitted.
    Re: Helix SMF kit.
    Ah cool. I took the price direct from helix at the time. I remeber emailing helix asking them if they could provide a heavier duty unit capable of above 400 ft/lb. It was a no at the time but things nay have changed.
    Oct 2009
    Doncaster
    Re: Helix SMF kit.
    You can get a >400ibft now from Helix.
    It for some reason is much cheaper to ring a distributor that helix direct.
    If your serious, I would ring Paul @ RS tuning and tell him the Andy sent you.
    Mar 2004
    Coventry
    Re: Helix SMF kit.
    Terry found he was spending far to much time dealing direct even with traders let alone joe public hence no longer offering cheaper direct
    DG
    Re: Helix SMF kit.
    Cheers. I have a single mass r26.r flywheel r26.r cover and an AP organic sintered plate. All bought relitavely cheap. I'm hoping it will last for at least a mapping session
    After that I may stick with the cover and pop in a 6puk plate.
    Oct 2009
    Doncaster
    Re: Helix SMF kit.
    I think it will slip if you are going for serious torque ..
