Results 1 to 11 of 11
    norwich
    Gearboxes
    Hi all, just a quick one, maybe obvious but wanted to check, looking at gearboxes and just wondered if the code started with j it has the same mounting points/casing?
    Bit of research and I found out j in the engine code meant manual ie c1j
    So does that mean that although it starts with a j it just means it's manual rather than casing/bell house design?
    Kent
    Re: Gearboxes
    C1j has nothing to do with the gearbox code 'J'.....
    Any JB or JC gearbox had same bolt pattern to fit the C and F block engines.
    norwich
    Re: Gearboxes
    Thanks for the reply Matt
    I know the engine code has nothing to do with the gearbox code. I had been researching, without much luck, but found a breakdown of codeing, didn't read it correctly obviously and probably couldn't find it again if I tried.
    So it's just jb & jc with the same case?
    So J series has no relation to anything and the second letter the casing?
    Non-member Chunk's Avatar
    Oct 2010
    Loughborough
    Re: Gearboxes
    Not necessarily, some JB1s and JB3's have different casings as the starter motor mounts on the front of the block on some Renault engines
    Just have a look at the box and make sure the starter motor is at the back and it should be ok.
    Kent
    Re: Gearboxes
    Sorry mate (TNT) wasn't trying to teach you to suck eggs!!!
    The gearbox coding is as follows....
    Kent
    Re: Gearboxes
    Quote Originally Posted by Chunk View Post
    Yes that's true, and the change mechanisms can be on top as opposed to underneath. But, that's mostly due to later engines and gearboxes.
    norwich
    Re: Gearboxes
    No problem, I got to the point I was confusing myself and thought it best to just ask . That's exactly what I was looking for thanks
    Thanks for the replies guys, think I'll knock that idea on the head and stick to what I know, which isn't much now a days
    Dec 2012
    Re: Gearboxes
    does anyone know difference between standard box and gt turbo. first 3 letters are same ..jb3?
    Kent
    Re: Gearboxes
    Mostly down to the ratios, jb3014 for example the 014 denotes the ratios.
    Dec 2012
    Re: Gearboxes
    thanks matt. is it longer gears or shorter do you know. more or less top end? didn't know if turbo ones are bit stronger? thanks again
    Kent
    Re: Gearboxes
    Try this mate.
    http://www.getflat.co.uk/phcdownload...2/MRBVJBJC.pdf
    Gives you repair methods and ratios.
