Results 1 to 15 of 15
    Committee Member
    Events
    Slammed 66's Avatar
    Nov 2011
    Grimsby
    Baffled sumps
    Just another thing that I'm sat here pondering about. I intend to use my phase 1 mainly for 'fast road' use but with the occasional trackday thrown into the mix aswell.
    Would it be advisable to look into getting a baffled sump? I'm sure I've seen the plates for sale somewhere but can't remember where. I also recall mention of phase 1s having a baffled sump but may have just dreamed that bit up
    Is it overkill for my intended usage or a wise move?
    Ross
    Non-member car.crash's Avatar
    Aug 2006
    Re: Baffled sumps
    The cars have made it this far without them
    Some ph1 cars had them. I did have templates to make them up but binned them when I sold up and gave my baffled sump away, can't remember who took it now.
    Plenty of us have done track days without them and drove home.
    I personally wouldn't bother.
    Oct 2012
    A
    Re: Baffled sumps
    What exactly is it? Does it hold more oil?
    Oct 2003
    Re: Baffled sumps
    yeah check your sump, i had an engine out of a ph1 and it defo had a baffled sump, i sold it on here not too long ago
    Re: Baffled sumps
    Stops oil moving around within the sump as much on fast bends
    Committee Member
    Events
    Slammed 66's Avatar
    Nov 2011
    Grimsby
    Re: Baffled sumps
    That's a job for the weekend then
    Re: Baffled sumps
    Nice if you can get one (I have) but not essential as many have proved. They're found in the PH1 GTT and the R11 Turbo.
    Committee Member
    Events
    Slammed 66's Avatar
    Nov 2011
    Grimsby
    Re: Baffled sumps
    Are the pickup pipes the same length on the baffled sumps?
    Aug 2006
    Re: Baffled sumps
    The sump is the same, it just has a flat plate bolted in with 2 wings.
    It has a cut out for the original pickup.
    http://sites.samfish.co.uk/r5bits/-elf-cup-car-bits-1
    Committee Member
    Events
    Slammed 66's Avatar
    Nov 2011
    Grimsby
    Re: Baffled sumps
    Excellent.
    Thanks for that everyone
    Non-member andybond's Avatar
    Oct 2009
    Doncaster
    Re: Baffled sumps
    I am not sure you will need one Ross. Unless you are going round a long, long bend ( and I mean long - like at Mallory Park ) on one , there isnt much chance of oil starvation.
    I would be more worried about falling off the blackstuff !
    Oct 2012
    A
    Re: Baffled sumps
    Cheers guys. Learn something new every day!
    Non-member GTphil's Avatar
    Re: Baffled sumps
    I remember when stu clarks old red GTT threw a rod bearing at the bruntingthorp national day a few years back, was the situation above that caused it.
    As has been said above other than this exact scenario the gtt doesn't need a baffled sump, so as long as you don't have a passion for going round and round roundabouts at high speed I wouldn't worry
    Committee Member
    Events
    Slammed 66's Avatar
    Nov 2011
    Grimsby
    Re: Baffled sumps
    Chris curve at Cadwell park is a long fast sweeping right hand corner and seeing as this will mainly be where I do trackdays, it may not be such a bad idea. Especially since the engine is out of the car at the moment.
    Thanks for your input
    Non-member jamesy12345's Avatar
    Sep 2013
    Re: Baffled sumps
    Have a look at this months issue of Practical Performance Car - they make a baffled sump for their Delta Pig, and change the oil pick up pipe too
