Results 1 to 6 of 6
    Dec 2012
    help
    does the upper steering columb need to be removed to change the bottom bearing? if so how hard is it to take out? Is it possible to put the exisiting one back in it seems to have dropped down and is loose...
    Re: help
    https://www.rtoc.org/boards/showthread.php?t=4731
    It's been such a long time since I did it I can't remember the ins and outs. You at least have to drop the upper part. Personally if I was doing the job I'd just replace the 2, it's not as big a job as the pictures make out.
    When the bearings wear out they can fall down from inside the rubber bush and end up at the bottom of the column.
    Dec 2012
    Re: help
    Thanks alex thats a great help. Just waiting on renault to see if tgey have them in stock. Fingers crossed lol
    Dec 2012
    Re: help
    Afyer spending 3 hour taking the steering columb out and refitting the bottom rubber. Put it back together and worked for all of 5 minutes before the bottom bearing popped out again.
    Gonna order some from mike tommorow unless they dude off ebay with a conplete upper columb replies to my msgs. Off the rd for the weekend grrrr....
    Dec 2012
    Re: help
    result managed to get a complete upper steering columb for £15 going to go pick it up after lunch happy days
    Dec 2012
    Re: help
    On the warrington my clutch self adjusting ratchet broke. Rac recovered me half way back to leyland. Had to pay another recovery guy 40 to get home gutted. Oh well bigger list for mike. Need a clutch pedal and steering columb rubber bearing.
