Page 2 of 2 FirstFirst 12
Results 51 to 56 of 56
  1. #51
    Nov 2008
    Croydon
    Re: My winter project 5
    They missed the fact that the AEI has been relocated behind the firewall. Shoddy knowitalls
    And the fact it's got the wrong suspension on it
  2. #52
    Non-member andybond's Avatar
    Oct 2009
    Doncaster
    Quote Originally Posted by Andy M View Post
    Not on that car. Its an E plate , and has the ph1 setup on it ..
  3. #53
    Nov 2008
    Croydon
    Hairy muff Most E's I have seen (including one I previously owned) are PH1.5 and have the later suspension but there must be a few that old style struts fitted. The lottery of the parts bin at the factory
  4. #54
    Non-member bood's Avatar
    May 2011
    hows this coming along?
  5. #55
    Jan 2014
    Quote Originally Posted by bood View Post
    Slowly but surely,
    I've just this week got it taxed and driving around as I've had rear light connection problems so I replaced n/s loom front to back and cleaned up the connections in the holders. And all is well. I also have removed the remnants of a Clifford alarm and airhorn And associated wiring, I fit a cool running thermostat and new relay and removed the In Car fan switch and wireing as I'm only running standard boost it was pointless. Traced a waterleAk in passenger footwell coming from heater matrix so I have disconnected that until I have time to take dash out and replace the unit. I've got 2x carbs and neither was set up for standard turbo so I am running rich and need to get that sorted. The windows motors were slow and non moving so I have replaced p/s and all I'd well but I will need more time on d/s as that goes down but not up.
    Fitted various gaskets the engine, ordered a soft clutch kit fixed the headlight issues replaced bumper. Once I get on top of my running issues I've got a 2wd cossie cooler to go on that was pressure tested and painted and alloy welded at NRG. I'm sure there's more I have done and I still have lots to do.
  6. #56
    Jan 2014
