Results 1 to 4 of 4
    Oct 2003
    DTA e48 ecu
    For sale dta fast e48 ecu with the 7.5A firmwear, i have a copy of the wiring diagram and instructions to go with it (printed off the website) surplus to requirements, no loom or cable with it but perfect for those looking for an easy to use ecu. £250 ono
    copied from dta website
    E48 EXP ECU Main Features
    Full Ignition control and amplification for up to 4 cylinders distributorless, 8 cyl with distributor
    Full fuel control of up to 16 injectors (staged and switchable on RPM in 2 banks )
    Amplified Coils Support NEW
    Compensation for air temp / water temp / MAP or barometric pressure on fuel AND ignition
    Closed loop Lambda control
    Turn off closed loop above TPS & RPM NEW
    Full turbo pressure control variable by RPM with overboost protection
    Manifold Pressure as main load NEW
    Full single gear traction control (launch control)
    Steering wheel button controlled start line RPM limit
    Full power shift cut
    Temperature dependant Idle speed control via PWM valve (shared second bank of injectors)
    Auxiliary output switchable on RPM / water temp / manifold pressure (shared turbo control)
    Dedicated shift light output
    Dedicated Tacho output
    Two stage main RPM limiter
    Dedicated fuel pump control
    Full startup fuelling map
    Improved idle speed control NEW
    Throttle transient enrichment map
    Self test facilities for ignition and injection
    Sensor diagnostics and peak recording
    Real time mapping, no EPROM's required, PC only or PC+Dyno Control Box
    Voltage in warning limits during Mapping NEW
    Software programmable for most crank wheels (BMW, Ford, GM, Porsche, Renault, Honda Blackbird, Rover, VW, 361, 602 etc.)
    All main 3D maps (20 x 14) have user programmable break points on throttle and RPM
    Max. RPM 14,000
    Non-member DeanmGT5's Avatar
    Aug 2013
    Re: DTA e48 ecu
    Hi mate
    Im interested in this, whats your best price
    Oct 2003
    Re: DTA e48 ecu
    drop me a pm and we can go from there
    Oct 2003
    Re: DTA e48 ecu
    SOLD
