Results 1 to 8 of 8
    Non-member Benjibrady's Avatar
    Jun 2011
    Bruton
    Anti lag?
    Whilst in dreams of different set ups this pondered my mind, is it possible? It's fuel injected so in theory it's possible? Has anyone tried it?
    Non-member SCHWARTZ's Avatar
    Wallington south london
    Re: Anti lag?
    Anti lag is harsh on everything and imo not worth it on a road car. I get full boost easily by 3k and it dosnt feel laggy. Launch control is a lot less harsh on the valves etc... Even that is a bit ott on a road car but its worth it for the pops and bangs.
    Non-member olidaviesuk's Avatar
    Nov 2008
    Bromley
    Re: Anti lag?
    Yes it's possible with the right engine management, will wear out your exhaust valves and turbo seals in no time though
    Non-member r5 rich's Avatar
    Romford, Essex
    Re: Anti lag?
    My friend has it on his evo 8 MR both active anti lag and launch control. It is well worth having on a car like that due to the 4WD system and in 1st gear just floors the throttle to the floor and it will sit at 3k ready to go. Does cause a problem to his neighbours when its popping and banging coming home and he has had a few complaints from the old bill in the past too
    Jun 2011
    Bruton
    Re: Anti lag?
    yeah I do like the idea of an anti lag system, after reading up it seems that you can get them set up to deliver different levels of boost, i.e. 5psi for a more mild set up
    Non-member stu21t's Avatar
    Re: Anti lag?
    I love the anti lag on my 5, got launch control too but not been able to fully test it yet.
    Member robw's Avatar
    Re: Anti lag?
    Unless using your car for competition completely pointless imo.
    Oct 2003
    Re: Anti lag?
    used to be great for drag racing in my s4, mapped it in on the stock ecu, and used the throttle position to regulate boost, would launch from .1 to 1.3 bar. got my heavy beast of a car down the strip rather quickly for its power, that and the flat shift. Pointless on the road though, unless you wanted to give pensioners a heart attack. great for catching bikes out at the lights though ;-p
