Page 4 of 5 FirstFirst 12345 LastLast
Results 151 to 200 of 239
  1. #151
    Non-member Dre5gtt's Avatar
    Aug 2013
    Spending more on cars
    Re: My Electric Blue Renault 5 GTT
    Very, very nice. You've really made a huge improvement to this car in the time you've had it.
    Maybe I asked this before but are there any decals on the way?
    Thanks mate yeah I have some decals but I found a little paint bubbling at the front drivers door I waxoyl the inside of the doors when I had the cards off and all is fine in there so going to get that sorted before I put the decals I have on
    Thanks Nad and safehands
  2. #152
  3. #153
    I like this car very much
  4. #154
    Aug 2013
    took the car up to Dynodaze rolling road at hinckley yesterday
    I made 133bhp and 154 torque at 15 psi of my little t2.
    I done 240 miles yesterday as i drove to London last night everything running sweet as a nut pulls nicely no overheating issues just i think i need to do a rear wheel bearing but that's it
    here are some pictures
    dre
  5. #155
    Feb 2011
    Down South
    nice clean car there boss
    also good to see romils is still alive
  6. #156
    Non-member Goobie's Avatar
    Mar 2002
    East Sussex
    Top update.
    Car coming along nicely buddy.
  7. #157
    Aug 2013
    lol cheers peeps yeah Romils car is a machine goes everywhere had a full workshop in the boot to
  8. #158
    Feb 2011
    Down South
    Quote Originally Posted by Dre5gtt View Post
    just in the boot???
    normally its on the seats and in the footwells too, it would be faster if the tools wernt everywhere
  9. #159
    Aug 2013
    lol yep come to think of it yeah everywhere romil should be an aa man for us 5 drivers
  10. #160
    Aug 2013
    over the past week i have done the rear wheel bearings and started to take my side skirts and arches off the car.
    i did not know what to expect as we all know it hides alot but im happy with the car its solid just needs a Little welding which is getting done on the weekend. So i started to rub and treat any surface rust that i could see and started to underseal when happy
    had to drill out the rivets i have some stainless nuts a bolts on order
    arches all round are in great condition
    this is the bit that needs welding going to cut this all out and re plate
    the goods
    rubbed down any surface rust and treated. zinc primer ed and undercoated
    other side
    this side had a little hole in the seal the rest is solid
    going to strip the inside tomo and change my rear cards and take the seats and carpet up to
  11. #161
    Norwich
    Nice work, looks in pretty good shape under the kit mate
  12. #162
    Non-member Jimmy5's Avatar
    Oct 2010
    Looks really well and tidy under the arches. Has been looked after in the past. What mm you lowered? As that's a really nice stance your car has.
  13. #163
    Aug 2013
    cheers peeps well after finding some water in the car and the matrix heater leaking thought i go on the mission and rip the dash out looks like its been leaking for a good few years and rotted some of the floor to so my mate will be busy this weekend cutting and welding my car good old french motors sills and arches solid for once and now this glad i have done all this because once its done it will be a solid motor my Clio Williams was worse and saved that from getting scrapped and still looking mint now so let the restoration begin
    where the leak was
    leaking old matrix out
    new matrix in
    inner sills are solid
    will update tomo not looking forward to putting all this dash back together looks a ****ing mess at the moment oh well got to be done
  14. #164
    Aug 2013
    Quote Originally Posted by Jimmy5 View Post
    35mm on front not sure on rear mate
  15. #165
    Oct 2012
    A
    That's pretty solid mate. I've seen loads worse than that mate.
    You're car OCD is as bad as mine lol.
    Good to see your keeping busy with it! It's a cracking car!
  16. #166
    Aug 2013
    lol i am quite bad with things being in a good way
    suppose its not that bad that leak has fooked things up but can easily be sorted
  17. #167
    Oct 2012
    A
    It'll be stronger than ever mate with fresh metal. Looking forward to seeing it!
  18. #168
    Aug 2013
    cheers mate look forward to it being put back together
  19. #169
    Non-member greggtt's Avatar
    May 2010
    Awesome car mate wish mine looked that good!!!
    Top job
  20. #170
    Aug 2013
    Cheers Greg the cutting has started
  21. #171
    May 2014
    Really not to bad underneath, it's a credit to you, lovely looking motor.
  22. #172
    Aug 2013
    chris
    got alot done to the car nearly all back together and im happy that its solid again
    this is where it leaked from the window where it was not sealed properly was running down and water was sitting behind and rotting
    this is where the matrix heater was leaking to so if it was not for these fooking leaks car was solid
  23. #173
    Aug 2013
    so the cutting and welding began
    had to double skin this bit
    rubbed down all the surface rust and treated
  24. #174
    Aug 2013
    carpet cleaned
    outside sills all done
    drivers side
    rubbed down all the floor of any surface rust and treated and painted plus i re undesealed the bottom of the car
  25. #175
    Aug 2013
    scuttle panel all sorted and back together
    got some phase 1 cards as my phase 2 cards started to sag
    [IMG]http://i1347.photobucket.com/albums/p714/dre_williams1_2/R5%20GTT/33864E48-1D72-4E2E-ABEF-5F385FBC43D4_zps5ahmu0kh.jpg[/IMG
    and this is where i am at the moment
    dash is back and everything is working had the car running and bleed the system to
    just got to put the seats put my side decals on and kit on
  26. #176
    Non-member Mattw's Avatar
    Jan 2010
    Burghfield common
    nice work mate. Looks very tidy
  27. #177
    Aug 2013
    Cheers mate yeah I'm happy with it always scary taking the kit off
  28. #178
    Jan 2010
    Burghfield common
    It's like Russian roulette
  29. #179
    Aug 2013
    Lol yep I had a Clio Williams that was 8 years younger then this and that had quite a lot of rust, this has been looked after well solid little motor
  30. #180
    Jan 2010
    Burghfield common
    And should last another couple of decades at least with your help mate.
  31. #181
    Aug 2013
    I hope so mate this car is a keeper for me
  32. #182
    Jan 2010
    Burghfield common
    same as that mate cant see me ever getting rid of mine.
  33. #183
    Apr 2011
    Netherlands
    You should cherish this one mate!
  34. #184
    North West Area Rep LukeRobbo's Avatar
    Nov 2008
    Cumbria
    Looks great on them wheels in that colour.I put a France flag on my towing eye cover in 2008 and wonder if I started a trend? :-)
  35. #185
    Aug 2013
    Will do mate can't wait to get my decals on just to finish it off
  36. #186
    Aug 2013
    Quote Originally Posted by LukeRobbo View Post
    Cheers mate yeah it was you that I copied, loved it as soon as I saw it on your car
  37. #187
    Aug 2013
    Managed to get a bit of time to put the seats back in the car and clean them to
    Sorted my sills all sealed and protected ready for side skirts to go on
    Just my side decals to put on now then the rest of the kit can go back on
  38. #188
    May 2014
    That is immaculate, excellent work.
  39. #189
    Apr 2011
    Netherlands
    This is just awesome mate! Bringing it to National day?
  40. #190
    Aug 2013
    Quote Originally Posted by Chrisxr2 View Post
    Thanks glad you like it
  41. #191
    Aug 2013
    Will be at FCS on show day mate will pop over to say hello I will be parked with the Clio wiliams lot, been a member for years and I owe a Williams to so if you see a light blue r5 in the middle of a few clios it's mine I see your a member on there anyway
    Hope to catch up soon
  42. #192
    Apr 2011
    Netherlands
    yeah i'm a member on multiple boards would be nice to have a chat, although i'm affraid the weekend will be way to short to catch up with everyone including Cliosport
  43. #193
    Aug 2013
    Got some stainless nuts bolts and washers for my skirts
    Both skirts back on and I am going to attempt to put the decals on myself hate doing stuff like this
    Had a go putting the first bit on, the door is going to be the worse part to do has to be trimmed to
    Will be doing the rest later got to pop out for awhile was not that bad with the soapy water method
  44. #194
    Moderator
    South East Regional Rep
    LiamR's Avatar
    Dec 1998
    Medway, kent
    The interior looks great. Very impressed!!
    Good that your having a pop at putting on the side decals too. I don't think I am that brave!!
  45. #195
    Jan 2010
    Burghfield common
  46. #196
    Aug 2013
    Quote Originally Posted by LiamR View Post
    yeah wanted to get someone to fit them but FCS is next sat so just want the car finished
    Got the rest done just need to put the kit on once I have cleaned and waxed the whole car
  47. #197
    Norwich
    Great work, one very fresh 5!
  48. #198
    Aug 2013
    Cheers mate
    Got a lot done over the weekend gave the underneath an other good underseal so that's all done now, also washed, clay, polish and will wax it on Friday before FCS all the kit is back on now to
    That's it all covered up till the weekend now will give it a good wax and clen the wheels on friday
  49. #199
    Moderator
    LiamR's Avatar
    Dec 1998
    Medway, kent
    Your car looks great!
    Look forward to seeing it at the weekend
  50. #200
    Aug 2013
    Cheers mate lets hope for some good weather, see you on the weekend
