Results 1 to 5 of 5
    Non-member cpt chunk's Avatar
    Feb 2010
    South London
    Boosting off the gauge..
    I have recently got my Raider running again for the first time in 4 years.. Shes got new Battery, actuator, plugs, rotar cap, silicon hoses and a second hand carb from Mike @ GT Turbo Spares. Ive removed the anti perc fan, overboost senser, the in-car boost adjuster it had, and have done the cup mod, and fitted a oil breather pot..
    The Prob is i have noticed that it it boosting way too much ( The boost needle goes all the way round as far as it can go!
    I dont remember it being like this before.. What have i moved? and how do i turn it back down?
    Cheers,
    John
    Non-member JRP's Avatar
    Nov 2001
    Hogwarts
    Re: Boosting off the gauge..
    Adjust the actuator arm. Best check what it's set to fuel though, have you an AFR gauge?
    Nov 2001
    Hogwarts
    Check the hoses to actuator are on right too.
    Check the actuator hoses are on correctly and the preload on the actuator
    Non-member philr5t's Avatar
    Dec 2008
    tadworth
    Or check you have put the actuator piping round the right way mate as if there swooped this will give you the issue your having easy mistake I've done it
