I have for sale a copy of the Prima 1.7 turbo engine they use to sell years ago for the 5
This one I have done use's a B18FT bottom end, a GTX head, modified inlet manifold and a tubular exhaust manifold.
The bottom end I've used is a good used item I've had for a while (Dave R5's old bottom end), the GTX head checks out ok and has been cleaned up
Inlet manifold is good condition although the exhaust manifold does need attention, it could do with a few areas being welded up and possibly strengthened
Has the GTX flywheel fitted so it works with the GT's AEI unit
Its had new headgasket and inlet/exhaust gasket fitted
I do have a GT carb for this engine too which I will sell with it also
If have any questions will do best to answer them for you
Like £250 for everything, collection only as it's too big to pallet up and courier
