Results 1 to 12 of 12
    Apr 2013
    Dublin
    HELP !!Back Axle stuck
    I'm trying to raise the back end - axle stuck solid any ideas?
    Non-member SCHWARTZ's Avatar
    Wallington south london
    Re: HELP !!Back Axle stuck
    Axle or torsion bar stuck?
    Apr 2013
    Dublin
    torsion bar - stuck
    Slide hammer or big hammer. Brute force
    Feb 2011
    Carshalton, Surrey
    how are you trying to get the torsion bar out?
    Non-member GTphil's Avatar
    HEAT!
    Bolt, nut, washer, big socket
    Member Woznaldo's Avatar
    Canberra, Australia
    Safest, most efficient way.
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    They can be a pain. Usually it is the bars that sieze in to the center block. If it doesn't shift with a big slide hammer than you need to heat that block, but be very carefull, the fuel tank is right there so you'll need to improvise a heat shield from some sheet steel or similar.
    Feb 2011
    Carshalton, Surrey
    I took these when i did mine a while back, might help.
    Non-member gttjames's Avatar
    Cambridge
    yes jeff - same method i use
    Apr 2013
    Dublin
    great stuff - thanks guys
