Results 1 to 14 of 14
    cambs
    return valve help me plz
    hi guys does anyone know were the return value is because when i pump my pedal my revs go up i trying at the servo but could nt find it
    Re: return valve help me plz
    Quote Originally Posted by mad manz View Post
    Check the one way valve on the back inlet manifold mate, if your not too sure where it is is directly behind the carb on the manifold there will be 2 of them one for the brake servo and one for the breather pipes
    Non-member Nayls's Avatar
    Weymouth
    follow the pipe from the servo to the manifold
    Non-member bones660's Avatar
    crewkerne
    when you pump the pedal , the revs will increase . not by much but they do increase .
    Non-member RICHIE's Avatar
    Jan 2004
    BEDFORD
    its on the back of the manifold there are two of them
    cambs
    there is two pipes but no return valve wot that about?help
    the bit that looks like a big nut that bolts into the manifold is the 1 way valve.
    cambs
    so its not part of the pipe then ?
    correct, not part of the pipe.
    you need a 21mm or 22mm spanner to undo the valve once you've taken the pipe off. you can check the valve by blowing through it both ways, obviously you should only be able to blow "into" the manifold, not out of the manifold
    cambs
    i have i look 2morrow and let u know thanx m8
    Non-member Adam 005's Avatar
    Dorset
    it's normal for thr rpm to fluctuate when you pmp the brake pedal at idle
    cambs
    but it goes from 1000 rpm to 1500 plus rpm that can be rite just by pumping the pedal?
    crewkerne
    no , it isn't . if your tick over was 1000 rpm it would rise to about 1150 - 1200 rpm . but no more than that . some cars don't go that high .
    cambs
    yeh so im going to check return values then look for air leaks after i done my heads gasket
