Results 1 to 6 of 6
    Non-member SCHWARTZ's Avatar
    Wallington south london
    rev limiter types
    On the megasquirt I have options for the rev limits for the main hard and soft cut rev limits but also launch control rev limits. The options I have is fuel cut, fuel and spark cut, spark cut. I have it set to fuel and spark cut at the moment but would I be better off (safer) to just cut The spark?
    Non-member gardner51's Avatar
    May 2010
    Re: rev limiter types
    I think spark cut is safer? Plus you'll get flames
    Flames? Spark cut it is then
    Dartford
    Spark only
    Probably should have stated if you didn't know or if it makes any difference its on a b18ft
    now all set as spark cut only awaiting flames I also have the option to ignore knock above a certain rpm, anyone know if i need to ignore after a certain point due to engine noise etc...?
