Results 1 to 5 of 5
    Nov 2008
    west midlands
    Wideband - AEM Meter Setting up
    Hi all , just fitted a AEM wideband ( Thanks Scoff / EFI parts ) , has anyone got any tips / info on how I should go about setting up the fuelling on my R17 ? , currently running super rich !!! Fuego turbo engine , 32 DIS ( got the extra enricher ), 1565cc , T3 ( std ) , Mild cam , ported + polished . Any thoughts , tips etc would be welcome Thanks Antony
    Non-member gtmatt's Avatar
    manchester,sale
    Re: Wideband - AEM Meter Setting up
    Quote Originally Posted by r17antony View Post
    Hi Antony rich on boost ?.rich on Idle ,what boost are you running , has the carb had a rebuild ? Could be ,many reasons well running rich , if its standard ,buy a carb rebuild kit.go from there
    Nov 2008
    west midlands
    Carb was rebuilt by Sparkie last year , the car has sat in the unit , thou run over the winter , was dribbling into carb , adjusted it to stop it cutting out , doesn't cut out anymore but you can smell the petrol , running 10.5 on the AEM at idle . Going to take it off again and give it a clean
    Nov 2008
    west midlands
    Re: Wideband - AEM Meter super Rich !!!
    Carb dripping even after stripping and cleaning it , running 10's on idle still , tried adjusting mixture screw , this helps then after it idle's for a while it starts again . running out of ideas .?? any thoughts out there ?
    If the carb has been rebuilt, the first thing I'd be doing is cleaning the idle circuit/jet out (big brass screw on the side) stick the straw in that you get on a can of WD40 and squirt a load in (for about 20 seconds) then clean the jet itself out. Also remove the mixture screw and make sure the tip hasn't snapped off. See how it is then.....
