Results 1 to 16 of 16
    Nov 2012
    Slovenia
    How to change starter motor?
    Hello,
    whats the easiest way to change starter motor? What parts should be removed?
    I was going to do it yesterday but I hardly found the damn thing...
    Thanks!
    Martin
    Re: How to change starter motor?
    Three bolts by gearbox at back which holds the starter motor in place. Undo wiring from under the car on back of starter motor and remove out passenger wheel area.
    Non-member StuHERTS's Avatar
    Sep 2012
    topcat did mine the other day,
    Undone the 3 bolts and jiggled it to move it out a bit to undo the cables (take a pic of it connected for when putting it back).
    Took drivers side wheel off for access then undone the bar.
    Helps if 2 get it back and bolted on.
    Nov 2012
    Slovenia
    Thanks!
    Theres is very litle room round starter, I think ill brake my fingers
    Don't know why put passenger wheel meant drivers
    Sep 2012
    Just take your time and record what goes a where.
    For good sake remember first to disconnect the battery as a broken finger will be the least if your worries lol
    Dartford
    I hope you repaired the **** wire connection on the starter solenoid...
    Motech Tony Walker's Avatar
    Sep 2005
    Parkgate Cheshire
    Also when reinstalling make sure you get the dowel back in to the correct hole, or it makes a horribe graunching noise when cranking.
    Sep 2012
    Yea, that was just temporary..
    Dartford
    Quote Originally Posted by StuHERTS View Post
    good lad, temporary becomes permanent otherwise
    Oct 2012
    A
    Re wire and new earth lead mate.
    ASAP!!
    Look-Out Kris M's Avatar
    Apr 2006
    Swindon
    Non-member J$£5GTT's Avatar
    THE BAT CAVE
    fit a heatshield on that starter!
    Sep 2012
    ASAP!!
    Sorted mate
    Triple shielded cable & Earth protection!
    and new belt as suggested
    Cheers
    Oct 2012
    A
    Pucker job stu.
    Sep 2012
    Cheers..
    The black metal elbow shield, how is it held on? I had to stick a very small bolt (you can see it) just in front of the bolt near where the earth cable goes to on the gear box.
    Is there another "support" at the other end of the shield to secure it?
    It looks fairly secure but i don't wan't it coming off!
