Results 1 to 28 of 28
    Feb 2011
    Down South
    rich afr's
    right been to garage today in this crap weather to do bits on mikes car, done tappets, got old rad rethreaded on oil way, fitted and the heating problem on boost is sorted, also checked turbo no play at all and replaced alot of blue water pipes, changed carb for the one i totally rebuilt, put all back together but the afrs are crap, the carb runs sweet but on tick over im getting 13.9, soon as i rev it goes to 10.9 and on boost about the same, i cant boot to much as i notice the oil return is fubar today
    120 main
    1.0 ac
    1.4 2nd
    any help always appreciated no air leaks, all new gaskets may have to put on carb back on and drill 2nd stage as all the afrs were great not sure helpppppp thanx mick
    edit also if i turned mixture screw would this help ive sealanted it but can remove it
    Non-member SCHWARTZ's Avatar
    Wallington south london
    Re: rich afr's
    A little turn in would help the idle afr's. Does the carb function properly? Ie fuel not dribbling out the emulsfier tube acc pump adjusted with a 5mm drill bit etc...?
    Re: rich afr's
    Mixture screw wont make any difference to on boost fuelling mate. Its probably due to 1.4 2nd stage, you will need to run a fair whack of boost to lean it off
    Feb 2011
    Down South
    Re: rich afr's
    nope none of this gaz i understand where ya coming from brigsy but the cars only running 14 psi at mo and i cant push to hard as oil return is fubar mate might just drill 2nd on the other carb this setup was
    120 main
    0.9 ac
    1.2 2nd stage
    but at 14psi @wot we we getting 12.4
    tick over was 14.5/14.8
    cruise was good too
    Non-member car.crash's Avatar
    Aug 2006
    Re: rich afr's
    The issue on boost is your second stage. 1.4 is to big for 14psi.
    I was 1.3 at 20 psi and still rich.
    Feb 2011
    Down South
    Re: rich afr's
    that would make it more richer gaz??
    Re: rich afr's
    Yeah swap it back, or rebuild that one as well then swap it
    Feb 2011
    Down South
    Re: rich afr's
    thanx mate was hoping to be running 20 ish soon it wont harm the turbo running a tiny bit rich will it?
    Non-member Logg's Avatar
    Re: rich afr's
    As other have said id expect that carb for a gtt running around 200bhp.
    Mike sort the oil leak and slowly up the boost one night until afr's are are around 11.7-12.0 obviously the leaner you are the braver/more confident you are in your set up. Ie act, ignition timing, cam timing and egt's
    Non-member casper's Avatar
    Jul 2012
    Re: rich afr's
    Mines
    1.0mm a/c
    120 main
    1.25 2nd stage
    20psi
    177hp
    afrs@wot are 11.
    Feb 2011
    Down South
    Re: rich afr's
    Quote Originally Posted by Logg View Post
    thanx logg so if its running rich all over this wont fubar anything only the plugs just ordered return so thats the next job, im confident about the cam timing etc but this threw me abit, maybe 1.4 is to much, maybe 1.3 would sufice, got got two other bodies on 1.2
    Feb 2011
    Down South
    Re: rich afr's
    Quote Originally Posted by casper View Post
    Mines
    1.0mm a/c
    120 main
    1.25 2nd stage
    20psi
    177hp
    afrs mate
    Jul 2012
    Re: rich afr's
    11@wot.
    Re: rich afr's
    thanx logg so if is running rich all over this wont fubar anything only the plugs just ordered return so thats the next job, im confident about the cam timing etc but this threw me abit, maybe 1.4 is to much, maybe 1.3 would sufice, got got two other bodies on 1.2
    How long you planning to run it like this? What you afr you got while cruising?
    Casper the higher the number the leaner it is. My 2p on what fueling should be.
    14.5-15.0 at idle
    14- as lean as you can get it with out hesitation off boost
    11.5 12.2 on boost depending your set up.
    And dont push much more than 20psi on oe pistons unless your happy playing russian roulette with your ring lands.
    Feb 2011
    Down South
    Re: rich afr's
    14.5-15.0 at idle
    afr tick over 13.9 ish
    cruise 10.9/11 ish
    wot not 100% as oil return
    if its going to be ok to run like this for 20 psi then no probs, my tungy ran 25psi on oe perfect circles no probs but i know what ya mean logg
    whats your recommendation mate
    Re: rich afr's
    cruise 10.9/11 ish
    Sounds a little rich a cruise wish I could tell you how to change that as I was lucky and had 15'at cruise on my carb so never had to fiddle with off boost fueling.
    Yep much more than 20psi and you cant be upset if it craps itself which I might push later this year since ive done 2k at 24 so far.
    Jul 2012
    Re: rich afr's
    Yeah I'm familiar with afrs now and am happy running@11 wot on my set up.
    Idle is 14.1 ish
    cruising 14 Ish
    part throttle 12s.
    Not really sure if the 11@wot is wasted fuel or a little bit of extra safety.Hopefully the latter.
    Re: rich afr's
    11's @ wot is prob wasting fuel and sapping power.
    Jul 2012
    Re: rich afr's
    Not bothered about the loss of power.
    Feb 2011
    Down South
    Re: rich afr's
    good man the other carb i took off was sweet 14.5 idle, same on cruise ish and wot 12.4@14psi think ill put old carb on and drill 2nd to 1.3
    this had 120 main, 0.9 ac, 1.2 2nd stage
    you got to love it when it craps itself mate, good thing with mikes is everything is new lol
    Dartford
    Re: rich afr's
    Have you checked to make sure that the acc pump is adjusted correctly mike?
    Should'nt really be dropping that low on cruising..
    Re: rich afr's
    14.5-15.0 at idle
    Whoa who said the stock piston ringlands fail at 20lbs? Ive ran over that for years and many others have. I ran 26lbs for ages standard comp, saying that there was no det and afr's of high 11's. I seen 7000rpm + in 5th a fair few times at this boost.
    Feb 2011
    Down South
    Re: rich afr's
    thanx dave yep did all that when i rebuilt it tbh these are the figures we were getting on the 140 main which we have soldered now to 120 i dont understand all i know is the carb i took off was sweet the spec now is the exact same apart from the 2nd stage being bigger which is for when boosting
    Feb 2011
    Down South
    Re: rich afr's
    thats what i said my tungy ran 25 daily on perfect circle oe mate
    Re: rich afr's
    Your not the only one lol four and a half years of doing at least 3 1/2 thousand miles a year. At varying boost between 15-25psi most of it at 20+.
    But I would never advise someone to run more much more 20psi until knowing there knowledge level and them knowing it could end in tears. There are far more people with failed engines at 22psi + than around 20.
    Feb 2011
    Down South
    Re: rich afr's
    heres the old tungy i refer too
    Feb 2011
    Down South
    Re: rich afr's
    i do agree with that mate
    Feb 2011
    Down South
    Re: rich afr's
    put the old carb back on today, while i did some other things for sangliers and alls fine, so im not sure whats up with the carb totally rebuilt, the specs on this carb are 120 main
    0.9 ac
    1.2 2nd
    afr idle 14/15
    cruise high 13/14
    wot not sure as not booted yet
    thought id let ya know
