Results 1 to 14 of 14
    Motech Tony Walker's Avatar
    Sep 2005
    Parkgate Cheshire
    changing water pump
    I had a bolt leaking on my waterpump so thought rather than tighten it up id take the pump off and reaseal it as its been on there years.
    Obviously one of the bolts snapped. so i ended up having to drill down the centre of the remainder bolt and retap it.
    Oct 2012
    A
    Re: changing water pump
    Right angled drill bit- a 5 owners best friend!!
    Peace of mind for a few years now mate
    Sep 2005
    Parkgate Cheshire
    90 degree drill head was ace couldnt of done it without it. I also cleaned the other threads out with the tap and couldnt believe the crap that came out. If i hadn't done that then the bolts may of bottomed out on the crap and not tightened up correctly.
    Sep 2005
    Parkgate Cheshire
    Ive also had a niggling feeling that my cam timming was slightly too advanced. Without the waterpump on made the adjustment all too tempting, i couldnt believe how much easier it was lol
    So its now been retarded 2degrees.
    And as soon as id started working on it, the rain also started pouring.... typical.
    Sep 2005
    Parkgate Cheshire
    Also cleaned the pump up a bit before refitting.
    Look-Out Kris M's Avatar
    Apr 2006
    Swindon
    have fun trying to get the timing cover to seal again in situe
    Sep 2005
    Parkgate Cheshire
    lol im a pro at making the cork gasket now, this is about the 6th bloomin time
    Sep 2005
    Parkgate Cheshire
    Heres one i made earlier
    norwich
    you do realize, that after posting this thread, you will be pestered for the rest of your days, every time somebody has a leaky water pump
    good job though
    Apr 2011
    I bought a 90 degree angle drill adapter a few months back thinking I prob won't use it that much, I've used it for so many jobs it's unreal, It even came in handy the other week to screw fixings into a wardrobe cornicing because there was no room to fit drill between ceiling and the wardrobe. Well worth the 20 ish I paid.
    I'm surprised you haven't invested in one of those special access timing chain covers
    Non-member AidenJ's Avatar
    Mar 2012
    i did mine when i had the head off for the second head gasket! Had 3 snapped bolts and all that was holding it on was a nasty mix of silicon and hylomar. now has shiny helicoils, fresh gaskets and no leaks
    norwich
    Quote Originally Posted by Nad-5GTT View Post
    the pro's know exactly where to time there cams in at on a certain grinds
    think my nose just grew another inch
    Sep 2005
    Parkgate Cheshire
    lol each time ive adjusted ive thought... no point getting a timing access cover as thats the last bloody time im doing it...... then i did it again...... then i did it again and again and again lol.... this really really is the last time now, i only did it as it was so easy to access with the pump off, i was pleased with the results where it was but i knew it wasnt quite there at the top end 6500>7000rpm and the dyno showed this abit too.
    Sep 2005
    Parkgate Cheshire
    Quote Originally Posted by AidenJ View Post
    Do it once and do it right i allways say...... altho this timing lark has perhaps ruined my reputation for that lol.
    And yeah i think i will invest in a 90degree adapter it really was a life saver and really smooth i was expecting it to be crap
