Results 1 to 12 of 12
    Feb 2011
    Down South
    getting warm on boost
    hi all, on the way to surrey meet we noticed on boost the car was getting warmer than usual only to the second mark but as soon as driven off boost back to first mark also got a bit of a oil leak off the 3rd bolt on the rocker box anyone had this before we got sangliers coming so it needs sorting, lucky got the stage 1 turbo technics still in shed if needed thx mick
    Dec 2004
    Aylesbury
    Re: getting warm on boost
    How old is the rad, also what type is it?
    Feb 2011
    Down South
    its a copper mark fairly old mate i thought this originally but it cools quick off boost
    Dec 2004
    Aylesbury
    Sounds to me like the rads blocking up, I've had this before a fair bit with those copper rads
    Best off fitting new standard item mate
    Feb 2011
    Down South
    thanx mark roughly how much is a new one thanx
    Dec 2004
    Aylesbury
    No idea, might be worth asking Mike
    Feb 2011
    Down South
    thanx bud
    norwich
    ren 5 extra van diesel rad use to be a doable upgrade also, had a slightly wider core area over the 5 gt o.e item, if you can find one on the bay etc
    more useful if running higher than stadard boost levels though
    Feb 2011
    Down South
    thanx mate can ya run the oe oil pipes to this still mate
    Flush the rad with a hosepipe first mate.
    Nope you'll need an external oil cooler and you'll need to extend the top coolant hose too.
    I used to run this setup when I was a c1j and I never had any temperature issues, even flat out on the dyno at 22psi, at 7000rpm
    Non-member Logg's Avatar
    Also you cant run a standard position intercooler with the diesel rad
