Results 1 to 20 of 20
    Jun 2006
    Bournemouth
    Williams f7r and megane f7r whats the differnce ?
    As title suggests whats the main differences between them ? Cheers Beardo
    Non-member Blick's Avatar
    kidderminster
    Re: Williams f7r and megane f7r whats the differnce ?
    my old man was on about this 2 me the other day as he owns a williams... he says there the same if u can find 1. think the rocker covers r slightly different but they put out the same power etc.
    Non-member rs250nut's Avatar
    Megane has coil packs where as the willy has a dissy, the inlet valves are 1mm bigger on the megane but still does not flow as well as the willy head. The willy block is stronger so Ive heard
    Jun 2006
    Bournemouth
    Interesting about the heads as i've been told the megane head is better for itb's !? Does anybody know where you can buy manifolds for itb's ?
    Why you planning some thing special? I think there is only one place that does fannymolds for the megane head and for the life of me I cant remember, bruce will probabley be able to help you with that one.
    Oxfordshire
    Quote Originally Posted by Beardo View Post
    Jenvey
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    the block is certainly different, the williams has a webbing cast in the back of it. otherwise I dare say they'd interchange ok.
    I may go down this route myself and delete the willy dissy and use the megane coil pack
    Jun 2006
    Bournemouth
    Nothing too crazy , just a sert of lairy cams and some itb's going to try and upset adey on the track !
    Oxfordshire
    swapping fuel and water cans usually works
    kidderminster
    between £100 & £180 seems2b the goin rate 4 these engines so not 2 bad... only know this cause my old mans lookin4 1 2 put in his kit-car. sorta prices hes seen them goin4.
    Jun 2006
    Bournemouth
    bugger me thats good , the only one i can find is on egay for £385 !!!!
    Sounds cheap to me to, you might get a fcuked one for that sort of money
    kidderminster
    only last wk a chap on the williams club there was 1 sellin 4 £180 cause he was scrappin the car, was down in derby i think... and u could hear it runnin.
    kidderminster
    there always gonna ask silly money on there!!!! ring around renault breakers... this time of yr they need the money and need2 get shot of things.
    Craig at apd for the manifold chap
    Non-member Adam 005's Avatar
    Dorset
    A good williams motor will cost over £250. a megane motor should go for no more than £250 as they are more common.
    Oct 2003
    try as you might you will not succeed ;-)
    Member Woznaldo's Avatar
    Canberra, Australia
    What model and year of Megane are we talking about? I want to check if they were available in Oz. I know that, if they are, they won't be going for 350 quid!
    kidderminster
    def talkin 96-98 maybe a couple more yrs either way. megane 2.0 L 16v sport
