Results 1 to 8 of 8
    Non-member danielmk323's Avatar
    malta
    sandwich plate
    can i use the c1j sandwich plate on the f7p bloke to use the oil cooler
    Non-member SCHWARTZ's Avatar
    Wallington south london
    Re: sandwich plate
    Don't know if this helps but I use the c1j sandwitch plate on my b18ft with the b18ft bolt. Think the b18ft and f7p blocks are basicly the same.
    malta
    Re: sandwich plate
    Don't know if this helps but I use the c1j sandwich plate on my b18ft with the b18ft bolt. Think the b18ft and f7p blocks are basicly the same.
    I am thinking the same is the b18ft whit the same water type sandwich as the f7p as standard
    Re: sandwich plate
    I'm using a c1j sandwich plate on my F7R
    norwich
    Re: sandwich plate
    Quote Originally Posted by danielmk323 View Post
    yes but i would run aftermarket cooler, 10-16 row depending on turbo aplication/boost levels, and access to airflow
    Non-member GaryS's Avatar
    Fleet, Hampshire
    Re: sandwich plate
    me two.
    Kent
    Re: sandwich plate
    Me 3.
    malta
    Re: sandwich plate
    I will to
