Results 1 to 40 of 40
    Non-member bernard's Avatar
    Devon
    cam timing??
    Im just a bit confused as were ive read in the hayes manual and other places it always sounds like the mark on the the cam sprocket should face the mark on the crank sprocket at tdc , but with the engine ive took out my five the mark on the cam sprocket point s away from the engine like in picture just want to confirm thats right.
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    Re: cam timing??
    Rotate the crank another 360 degrees!!
    Wirral
    Re: cam timing??
    Thats wrong if u ask me that , as you say the mark on the cam sprocket should face the mark on the crank sprocket ...... the way its done may have no effect on the timing not sure so it may be A ok , but if i was rebuilding it i would have it with the two marks facing each other at tdc if u want standard cam timing.
    Devon
    Re: cam timing??
    Thats why I think its strange in the picture its at tdc, and I dont think that engine has been touched cam wise since it left the factory.
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: cam timing??
    like ashy says, turn the crank another full turn! it's fine.
    Wirral
    Re: cam timing??
    mmm thinking about it , are you 100% sure you are at tdc ....???
    Oxfordshire
    Re: cam timing??
    like Ashy and Scoff say, turn it another 360 deg, and at the same time take a few minutes to read up on the principles of the 4 stroke internal combustion engine.
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    Re: cam timing??
    I might just lock this thread, getting sick of people not listening to me...
    Devon
    Re: cam timing??
    Pistons 1 and 4 are at there highest point so peeps im still learning, I thought this was a way of getting tdc
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    Re: cam timing??
    Quote Originally Posted by bernard View Post
    Do you have maths at 11+ level or above?
    Failing that, using your toes and fingers count the teeth on both sprockets and calculate how many times the big cog turns in relation to one rotation of the little cog
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: cam timing??
    and they will be again if you turn the crank another full turn
    Devon
    Re: cam timing??
    ok I will give it a go.lol sorry being a numpty
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    Re: cam timing??
    I assure you it will work
    Are you doing your first re-build?
    Devon
    Re: cam timing??
    yeah I am, Im still not to sure on how to do the timing proberley as ive fitted a piper 285 cam and veiner pully ive got the jist of it But still a bit unsure.
    this is my tread on a other site:http://www.renault5gtturbo.com/forum...=2656&start=60
    Non-member Mart's Avatar
    May 1996
    Pie & mash shop
    Re: cam timing??
    Good luck with the rebuild...
    Non-member raj's Avatar
    Feb 2001
    Rohtang pass
    Re: cam timing??
    bernard,
    with every [360deg] full turn of the crank pulley the cam pulley only moves half a turn.
    take your picture for example, yes both no#1 [flywheel side] and no#4 [waterpump side] pistons are at the top of there stroke. but with the cam pulley in that position it tells you that no#4 piston at the top of its compression stroke.
    so if you turn the crank pulley 1 full turn [360deg] you will then find that no#1 piston is at the top of its compression stroke and both the pulley markers will be directly facing each other.
    Oxfordshire
    Re: cam timing??
    a tip for fitting a vernier -
    fit the standard pulley first, then swap to the vernier without moving anything, that way you'll be pretty close when you start.
    Re: cam timing??
    Good pic in this thread. Never seen this part of the engine with my own eyes (i.e. I've never had to remove the timing chain cover thankfully), and never been able to visualise properly. Thanks
    Re: cam timing??
    Ahh, that's what the chain tensioner looks like! It's all so simple when you actually see it, lol.
    Devon
    Re: cam timing??
    Thanks for the advice guys, Andrew I ve done what you have said to do now can give me some advice to time it up propley from what I can gather I need to set to tdc on the protractor with a pointer then one of the inlet valves should be fully open at 112 deg is this right? sorry Im finding this quite confusing any tips would be brill.
    Devon
    Re: cam timing??
    Anyone?
    Oxfordshire
    Re: cam timing??
    do you have a dial indicator?
    engine looks good, how close to coilbound are your springs?
    Oxfordshire
    Re: cam timing??
    http://uk.youtube.com/watch?v=la6-EgnCOl4
    find TDC the same way as he finds the centre of the cam lobe (obviously using the top of the piston)
    Devon
    Re: cam timing??
    No I dont have a dial indicator (is that the same as a dial gauge?) Can it done without? im not sure what you mean about how close to coil bound my springs are??
    May 1996
    Pie & mash shop
    Re: cam timing??
    When you fitted that 285 cam, did you also change the valve springs?
    Devon
    Re: cam timing??
    yes I did matey.
    May 1996
    Pie & mash shop
    Re: cam timing??
    Piper's?
    Devon
    Re: cam timing??
    yeah I got the whole kit.
    May 1996
    Pie & mash shop
    Re: cam timing??
    Ok, you shouldn't have any coilbound issues then, assuming you aren't gonna go silly high with the revs (ie, Sparkie territory).
    Oxfordshire
    Re: cam timing??
    depends on shims etc, looks close to me. You check it at full lift with a feeler gauge. i wouldn't have mentioned it if it didn't look close in the picture.
    You will need a Dial indicator. I tried doing it using the "twiddle your pushrods" method and it's not at all acurate.
    Devon
    Re: cam timing??
    so does coilbound mean when a spring is to closed up?sorry for my ignorance.
    Member Woznaldo's Avatar
    Canberra, Australia
    Re: cam timing??
    Yes. Look at the picture above (bottom one) and you'll see the second valve spring in looks like it's almost at the point where it's been compressed so much that the coils are touchng (coilbound).
    Non-member Theros's Avatar
    Tampere / Finland
    Re: cam timing??
    Any good tips to adjust adjustable vernier pulley? I have 285 piper, T25 turbo, Twin choke carb, bigger valves, FMIC and so on.
    Non-member Billy-G's Avatar
    Feb 2002
    It changes. A lot.
    Re: cam timing??
    Quote Originally Posted by Theros View Post
    Do you have a Dial guage and a mag stand? If not, get one, Chronos do them for about £15. You'll need that to be bob on
    Re: cam timing??
    If your fitting a new timing chain, i would allow for some degree of strech/bedding in when setting up the vernier. I think me and mr ash allowed 1 deg which once run in should have been hopefully within 1 deg of 112.
    Oxfordshire
    Re: cam timing??
    translation - after pissing about for an hour we landed on 114deg, the pub was about to open and Ashy said "it'll stretch, mine's a pint"
    Devon
    Re: cam timing??
    Just to let you lot know I got all the cam timing sorted I got my local engine builders to do it in the end also the valve springs weren't coilbound so its all good done over 300 miles in the new engine and its all good well apart from a oil leak
    bracknell
    Re: cam timing??
    did you measure the mean opening or the point that it got to 112°
    the proper way is to work out the mean (ie average) and get the point on full opening smak on between 110° & 114° you have to measure the opening point and the closing point
    then your cam will be spot on
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    Re: cam timing??
    Just seen this hahahahaha
    Re: cam timing??
    Not before checking the bores for ovality if I know Matchew
    Using the original pulley to get somewere near seams to be the way George!
