Results 1 to 11 of 11
    Non-member danielmk323's Avatar
    malta
    F7p head gasket for turbo
    what people use on there turbo f7p any link will be nice and do the f7p and f7r use the same head gasket ?
    Non-member JP Racing's Avatar
    Apr 2009
    Ely
    Re: F7p head gasket for turbo
    Wont say what mine is, but think I could replace about 10 head gaskets before I get even close to that price
    Apr 2009
    Ely
    I didn't pay that money for mine it came with a head I brought
    Apr 2011
    Netherlands
    there are more gaskets available. cometic has mls gaskets too for less money.
    however when you're not going too extreme a standard head gasket could be used. the most probable cause a gasket blows is inproper tuning.
    My f7p turbo I just used a blue seal f7p mellior std headgasket from ktec cost me 30 inc postage it was decent quality. But then I was only running 14psi to be honest I would have still used the same gasket for more boost as its all down to state of tune
    norwich
    mls every time
    the others will blow under repeated higher boost, even if fuel/tune is sound
    all about long term reliability
    malta
    Quote Originally Posted by JP Racing View Post
    Tanks for the link but i can see that the gasket is for 83mm bore can it be used on the oe bore size
    norwich
    yes, depends on the block, if its oe, then yes , if its been re bored , you will need to check /or get it checked, but most are under 83mm bore so should be fine, if the bore is bigger than 83mm, get the 2.0 16v item for the williams, which 84mm
    here is the link
    http://www.performanceenginecomponen....asp?id=250593
    malta
    [quote=HAndy;321897]yes, depends on the block, if its oe, then yes , if its been re bored , you will need to check /or get it checked, but most are under 83mm bore so should be fine, if the bore is bigger than 83mm, get the 2.0 16v item for the williams, which 84mm
    here is the link
    http://www.performanceenginecomponents.com/products/product.asp?id=250593[/quote]
    Tanks for the info your the man
    Apr 2011
    Netherlands
    look on wilmink-performance.com, they sell cometics for around €120....
