Results 1 to 10 of 10
    Non-member gardner51's Avatar
    May 2010
    Carb trouble?
    Hi all. Trying to start the 5 but notice fuel is pissing out of the side of the carb, I presume diaphragm has split, so I order a new service kit, I replace the diaphragm which I can see has a little tear in it, put it all back together with new one. Try n start the car and the same is now happening? Fuel coming from side of carb?
    Any info would be great. Is their a reason why it's split again?
    Elliott
    Non-member Jonny5's Avatar
    Sleaford
    Re: Carb trouble?
    Is your float stuck?
    Could be causing the bowl to overfill and fuel to spill out?
    Just a thought
    May 2010
    Re: Carb trouble?
    Sorted it. Won't be saying what it was though haha
    Me being stupid!
    Trader
    GT Turbo Spares co.uk
    South East Regional Rep
    phase i 16 v turbo's Avatar
    Jan 2001
    Morden
    Re: Carb trouble?
    Glad to hear all ok!
    May 2010
    Re: Carb trouble?
    Will most prob be needing another rebuild kit
    Unless you can get just the diaphragm I need?
    Sleaford
    Re: Carb trouble?
    Quote Originally Posted by gardner51 View Post
    Me being stupid!
    Main fuel feed not attached?
    Glad its sorted bud.
    Non-member SCHWARTZ's Avatar
    Wallington south london
    Re: Carb trouble?
    Fuel feed attatched to the acc pump enrichment port?
    May 2010
    Re: Carb trouble?
    Fuel line attached to wrong place haha
    Think I am on the over flow. So shooting a shed load of fuel up it. And splitting diaphragm.
    Doh
    Apr 2011
    Re: Carb trouble?
    I bet we've all fecked up at some stage, I always do
    Non-member GTphil's Avatar
    Re: Carb trouble?
    I made a boo boo last year with the fuel supply to the carb, i had a larger bore feed pipe than the fitting and in my amazing wisdom instead of sorting it properly i packed out the fitting on the carb with insulation tape
    it spat it off and sprayed fuel all over the engine, luckily for me the engine was cold, if it had of happened half a mile earlier it would have been very different
    We live and learn
