Results 1 to 6 of 6
    Non-member markey b's Avatar
    Bury St Edmunds
    Aquamist water injection pump
    Has anyone got one of these kicking about? Mine has died again :-(
    Re: Aquamist water injection pump
    Mark ditch it matey now you have the Nodiz you shouldn't need it just retard the ignition when you here some det. The water injection just hides it better cooling also may need to be looked into
    Non-member JP Racing's Avatar
    Apr 2009
    Ely
    I found the water injection helped keep charge temps down as well as stopping detonation but if it runs out or packs up and you need it to stop det then bye bye engine agree that the best thing to do is just retard the ignition instead
    Bury St Edmunds
    Yup twice mine has packed up and cost me a rebuild, I like the idea of having there as a failsafe to be honest, Jp I'm now gonna txt u :-)
    Tipton
    you not thought about the sur-flo type of pump?
    Bury St Edmunds
    I emailed aquamist and was basically told my pump was discontinued in 2006, they offer no support or parts for it so I basically need a new kit... Charming
