Results 1 to 4 of 4
    Non-member GaryS's Avatar
    Fleet, Hampshire
    Charge cooler pump relay.
    Hello, where can i take a power feed from in the engine bay to activate my relay (for the charge cooler pump) when the car fires up?
    Thanks.
    Fleet, Hampshire
    Re: Charge cooler pump relay.
    All i need is a live feed when the engines running basically
    Non-member Mart's Avatar
    May 1996
    Pie & mash shop
    Yellow looped wire on the relay next to the aei.
    Non-member philr5t's Avatar
    Dec 2008
    tadworth
    Or put it straight on a separate switch so you only need it when your running on boost no real point running it on a permanent feed when the engines on tick over or sitting in traffic
