Results 1 to 6 of 6
    Non-member Marcel's Avatar
    Feb 2011
    The Netherlands
    witch radiator will fit my r5 tl 1.8 16v
    Hello
    i got this r 5 with the clio engine .
    the clio rad is touching the manifold .
    and is leaking now .
    what are there for options to get this or an other type of rad more in front and lower .
    and a wont cut in the subframe if there is an other option.
    are there other rads that fit like an vw or other brands that wil fit .
    who can tell me this .possible with pictures
    Re: witch clio radiator will fit
    I'm using a alloy version of the rad from a mk2 golf gti, does the job a treat
    Feb 2011
    The Netherlands
    maybe an picture of the rad .
    is this the 16v version or the 8v rad
    8v version as far as I know, will try and find some info for u fella
    This seems to be the only pic I have oddly, I know I took more but can't seem to find them
    Just robbed this straight from my project thread
    Ireland Co. Kilkenny
    when doing a f7p/f7r conversion in a 5 you need to use the renault 19 inlet manifold as its slighty smaller than the clio version so it clears the radiator.
    i got a r19 manifold
