Clifford alarm
Anybody interested in a removed Clifford concept 950 alarm system removed from a rover I used to own. Would need the pin code resetting which can be done using cliffnet wizard pro installers version as I can't remember what the pin was. Comes with the key fob and the alarm which has the wires mostly labeled and wires that I haven't figured out still have the original wires from the rover attatched so wire colours can be checked. Also has window microphone and microwave and tilt sensor
Was going to use it but doesn't have all the gadgets I'm after
If anybody wants more info or is interested just let me know
Cheers - rob
Re: Clifford alarm
How much you after for it mate? The pin code is the last four number of the black box serial number from memory
Re: Clifford alarm
Not really sure 60 quid? And I changed the pin to a personal one as the original one was just too long and it had anti jax etc so would def need cliffnet pro to reset it
Re: Clifford alarm
Is it a G4 or 5. How many remotes does it come with? Cheers
Re: Clifford alarm
It's a g5 and im 90% sure I have both fobs I'll dig them out tommorow just to double check
Re: Clifford alarm
Just found both key fobs on the master fob the light still comes on so battery is still good as for the back up fob it has no light to come on so may need a battery
