Results 1 to 33 of 33
    Stapleford
    Fuel sender removal
    A above it's being a pig and was wondering if anyone had any tips on making it easier???
    Re: Fuel sender removal
    Remove black plastic cover under rear bench, disconnet cable and pipes, create special tool by using exhaust section clamp as a handle and a long metal flat bar bar with holes in so you can bolt your ex section clamp onto then bend ends of rod so fits either side of the fuel sender unit and then you can turn it out.
    Non-member Mart's Avatar
    May 1996
    Pie & mash shop
    Stapleford
    confused as to why you have put this in???
    im looking for an easier way of removing it and which direction i need to hit it clockwise or anti???
    Non-member Tiny Tim's Avatar
    Oct 1999
    Bournemouth
    Quote Originally Posted by matty j View Post
    He's probably wondering why you've posted the same thing twice.
    Oct 1999
    Bournemouth
    Stapleford
    ^^^^^ lol
    Aug 2004
    Matt,
    You ad any joy using that tool... its any easy job to do... read your haynes, just make sure you tabe the hose's & wires down and out of the way.
    Remember its advised if use a new seal on it!
    Non-member Schakal's Avatar
    Barry
    un-locks anti clock wise
    Stapleford
    Quote Originally Posted by Penfold View Post
    Matt,
    No joy at all mate the one he made me doesn't fit so he's making a new one
    Tipton
    locate the end of the plastic ring.
    use a screwdriver and a hammer to knock it round anticlockwise.
    keep hammering until its come out of the hole....
    remove sender unit.
    Stapleford
    Right removed it easily and it was fine?? Cleaned it up put it back and it still reads full even tho it's not?? I've also cleaned the switch and it's still Reading wrong?
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    does it still read full even with the sender unplugged ? (the 3 pin plug on the top of the sender)
    Stapleford
    They read nothing empty then
    Non-member bones660's Avatar
    crewkerne
    put another sender in mate . there are many things that can cause a short . which is probably causing your problem . by fitting a new or good secondhand unit will eliminate the sender unit from your list of possible causes . if the gauge works properly after fitting a new sender . problem sorted .
    with electrical problems , it's all about elimination .
    hope this helps
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    new sender.
    Stapleford
    on it looking to get a one in good nick off here hopefully
    Tipton
    did you actually take the unit apart? - and physically see the circuit board with the little slider that moves over it along with the float?
    Stapleford
    yeah took it out and checked it and it looked fine
    Stapleford
    Fitted new sender and still reads wrong what next???
    Barry
    did you ever check the fuse ?
    Stapleford
    But If it was the fuse wouldn't it read nothing??
    Non-member raj's Avatar
    Feb 2001
    Rohtang pass
    mattys just fitted my spare clocks and the fuel gaude still seems to be playing up!
    the fuel gauge seem to twitch slightly, also when you put the indicators on the gauge twitches in sync with them.!
    Stapleford
    as raj said:
    its always reading near full on the gauge until about 5 mins before its empty, i have now changed fuel senders and clocks but no change?? help please
    Dec 2004
    Aylesbury
    Sounds like a wiring fault to me if the guage is twitching in sync with the indicator
    Non-member Gttnutter's Avatar
    Oct 2005
    Amersham
    noticed that mine does it very slightly today aswell sometimes on the footbrake i get a twitch
    Oh and mark need to do me handbrake sometime as its w**k
    Stapleford
    Is it easy to rewire??
    Oct 2005
    Amersham
    i would guess there its not earthing somewhere so maybe it would need tracing back?
    Dec 2004
    Aylesbury
    Quote Originally Posted by Gttnutter View Post
    Member Woznaldo's Avatar
    Canberra, Australia
    Have you checked the switching unit that's hidden behind the right rear interior panel?
    It's item 275 in WD115 (Auxiliary Pump Timer) the sender unit runs through it.
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    I'd say crap earthing somewhere too.
    start with the earth on the fuel sender, take it direct to something on the body for a test.
    Non-member Nick k's Avatar
    Leicester
    On the Aux pump circuit diagram does pin 3 on the sender go to the dash gauge?? and pin 2 is monitored by the timer module until it reads a certain resistance and then runs the aux pump??
    Canberra, Australia
    Yes and yes.
