Results 1 to 10 of 10
    Dartford
    172 sub frame
    Anyone know if they fit the 5 gt turbo? Are they the same as the original?
    Cheers
    Re: 172 sub frame
    I very much doubt it mate even a mk1 clio job is way different to a 5, besides I doubt there would be any advantage anyway.
    What were you planning?
    Dartford
    Re: 172 sub frame
    Cheers.. Not planning anything, there's just more around and in better nicked than most 5 ones these days..
    Kent
    Re: 172 sub frame
    If you wanted one that's Seam welded, give me a shout.
    Kent
    Re: 172 sub frame
    ..... I mean an R5 one not a 172.
    Oct 2004
    Somerset
    Re: 172 sub frame
    really matt.....
    Dartford
    Re: 172 sub frame
    Please that saves me a job
    Re: 172 sub frame
    http://www.cliosport.net/forum/showt...ubframe-to-Mk1
    It's been discussed in this thread above.
    If they won't mount to a Clio mk1 then its highly unlikely to fit a 5.
    A Clio Mk1 subframe will fit a 5 if you drill the subframe O/S front mounting hole back by 20mm or so. The other 3 subframe holes align perfectly with the 5 shell.
    I'm more interested in what was mentioned at the bottom of that post. Will 172 shocks fit a Clio Mk1 or 5 if 172 hubs are used... I think they may.
    Kent
    Re: 172 sub frame
    No worries, my stocks of sub frames are pretty much nil at the moment, I think Dave Clark had my last seam welded one for the yellow car.
    I can have a dig around at the back of the workshop and see if there are any left.
    I think it is possible to use 172 parts on the clio 1 and R 5.
    Foxy on CS did a 172 conversion and I'm sure Andy Cooke did the same to the rainbow car.
    Non-member AidenJ's Avatar
    Mar 2012
    Re: 172 sub frame
    I will have a 5 subframe for sale shortly thats in quite good nick.
