Results 1 to 6 of 6
    Sep 2009
    meath
    not fully boosting
    hey all,
    i have the car running somewhat good, only problem is on my private test strip i'm only boosting .5 bar my avcr is set to 1.3 @ 75% duty,
    its a GT28RS with a gt tunning front mount and hard pipe kit
    Re: not fully boosting
    Check the preload on the actuator and check for boost leaks
    Sep 2009
    meath
    preload? do explain. i didnt take the turbo off the manifold, i took it off complete and didnt touch it, it did run 24 psi though
    If you haven't touched the turbo you will most likely have a boost leak. Or you may have damaged the turbo when the old engine cracked a liner?
    Ireland Co. Kilkenny
    Quote Originally Posted by robx1r View Post
    did you have a electronic boost controler before if not you might need to set double the psi for what you want to run.
    Sep 2009
    meath
    i did the setup is exactly the same as before! must be a boost leak!
    time to start hunting!
