Blimmin passenger door refuses to stay shut , it clicks then just opens again, i have tried moving the old stay etc to no avail, any suggestions peeps or is it down to reno for a right spankin on a new one.......
o.k. your all asleep....., right , some string and then off to reno...cheers.
Is it not shutting properly when you try to, or is it closing completely and then popping open while you are driving ?
Have you tried WD40ing the mechanism?
Has the door dropped a little?
Definately time for a new mechanism then
i fitted 2 of them last year...about 45euro each which i thought was'nt that bad!!
i know of a mechanism for one of those,it comes
with a complete car though,its tucked away
all safe
for the dini right?
Blimmey that was quick , that definetely fit the old gt bud?, seems cheap for all that lot...
think your right matt,yep says door locks
could try ringing tho see what they got?
i did try squire!!!
I've got the same problem as you man, I think mine stems from the door saggin like mad. I'm on my seccond lock this year. The only way i can shut mine is to lift the door and slam it quick before i lose a few digets, or get my mate to slam it. He can do it every time somehow
LOL me too me too ! To get mine to shut Jesus i pull the latch down with a key or something then slam the bugger, works most times!
Did you remember to put in ''disconnect the negative battery terminal'' I swear they tell you to do it for removing the rear quarter windows.
I've got bored of the slamming so I got my dad to just climb across from the driver's side today. I should really make myself sort out the door pins in my 2 weeks hols, well can't be bothered though
Blast wd40 into the latch, work it open/closed a fair few times with a screwdriver, this will sort it. Had to do it to my gtt a few times.
I had this problem and sorted it a few days ago.My drivers doors drops so ordered some new pins which i havent fitted yet.Recently the door wouldnt shut so we made a new plastic bit that the the door catch clips onto on the small unimat laithe because it was smashed up.This didnt work so took the lock apart and oiled it up and noticed their was a bad burr where it had been rubbing on the worn door catch part.So got the dremmel out and took it off because that might have been the problem.
Fitted everything back together and it still didnt work but was better.Then decided to move the bit that the lock clips onto down slightly because we had it off and now it shuts fine.
I thought the door lock would have been more expensive than it is considering i payed £28 for a small wiper spindle off renault.Might fit new ones when i restore the car more.
