Results 1 to 23 of 23
    Jul 2011
    power steering conversion
    Hi peoples, is it poss to change my R5 to power steering and if so how hard is it??
    Non-member Nick k's Avatar
    Leicester
    Re: power steering conversion
    some people are running power steering. Alastair is running a saxo electric pump with a megane coupe rack, but this is on his hill climb car which has wide track so the megane rack fits ok. A valver rack is the close match to the 5 rack. Drop him a pm.
    Non-member andybond's Avatar
    Oct 2009
    Doncaster
    Doesnt the Monaco run powersteering ?
    I have a spare valver steering rack if required, going cheap.
    Non-member Goobie's Avatar
    Mar 2002
    East Sussex
    Would this just be a case of the above steering rack running the saxo/106 electric powered pump with built in reservoir, connect the power feed and two pipes to/from the pump/rack and away you go? Or is there abit more to it than that?
    Dec 2012
    Yes they do.
    Non-member Chunk's Avatar
    Oct 2010
    Loughborough
    That's pretty much it. You'd need to make sure the pump was on a Relay and only activated once the engine was started of course
    Mar 2002
    East Sussex
    Yeah, I was thinking along the lines of a switched live relay set up. It all sounds to easy. What would be the best steering rack for this conversion on a 5, Clio 16v option mention?
    Feb 2011
    Carshalton, Surrey
    I've been looking at Clio 2 electric power steering columns. Not sure if it will fit under a 5 dash though and the mounting points might not fit either and not sure if it will connect to a 5 rack but might find a cheap one and have a go.
    A place on ebay sells a controller so the power steering works...
    http://www.ebay.co.uk/itm/4003876655...84.m1423.l2649
    http://www.ebay.co.uk/itm/1810273144...84.m1423.l2649
    Mar 2002
    East Sussex
    From what I can see that wont fit with standard bottom dash cowling, but should be do able.
    Feb 2011
    Carshalton, Surrey
    I might find a cheap column and have a go then...
    Dartford
    You could also try a corsa c electric steering column you can get controllers for them too
    Non-member r5turbo2's Avatar
    Jul 2011
    Stamford
    Thinking about this for my r11t
    Feb 2009
    Walsall
    dont seem a bad idea mate be good if it works let know if it does
    Non-member 123-gtt's Avatar
    Nov 2011
    Not that I have any idea on the topic,but surly a Monaco rack would be the simplest???
    Same car same bits no fabrication
    Feb 2011
    Carshalton, Surrey
    have you tried a Corsa C Column?
    Dartford
    Quote Originally Posted by Jeff Ninebar View Post
    Yes, I've fitted one to my fiesta project & I also know someone who has fitted one to a Mk1 escort.
    Feb 2011
    Carshalton, Surrey
    I got hold of a Clio column and offered it up, the bolt fixings don't match so a plate would need to be made to mount it, not to hard to do.
    I tried connecting the upper clio column with all the PAS part on it to the lower steering column of the 5. The lower section needs to be about 1-2" longer as the electric motor hits the heater fan unit, I need to try it with the clio lower column onto the 5 rack but they measure the same UJ to UJ, so unless the clio UJ sticks up off the rack a bit more its not going to fit without a longer lower column. An extended lower column could be made by welding in a section or finding a longer part from another car.
    A fair bit of lower dash would need cutting back as well and the center vents would need modifying to fit the electric motor.
    Going to look at the Corsa C option, but looking at pics on the net I think the lower part of the column will hit the top of the R5 clutch peddles.
    I'm on a mission now though, so I will make this work, I think...
    Ivybridge
    Get a Clio rack, fit the r5 track rods. Bolts straight on.
    Mount a saxo/106 pump somewhere.
    Connect the pipes or get some custom from pirtek.
    Run a 50 amp relay and fuse (embattled merc ones are v cheap) from ignition live or switch.
    Job done.
    I wouldn't bother with an electric column, too much hassle.
    Ivybridge
    Job done.
    eBay not embattled ! Damned iPhone spell check lol!
    Feb 2011
    Carshalton, Surrey
    can't beat an iphone spell check
    Thanks for the info, will give this option a go next.
    I have some cheap clio racks if you require one? I found four in the garage! I just need to find the mounting brackets. PM me if your interested.
    Feb 2009
    Walsall
    Im after a clio rack.. Anyone? Can i use one off a megane does anyone know? Obv same year as mk1 clios.. Or the 1.2 clios? Same rack if any have PS?
