water pump bolts
hi,just spoke to renault regarding the 7 water pump bolts,apparently theres different mm sizes,does any one know what size i should order,,or where else they can be bought? cheers
Re: water pump bolts
i think they're jus m6 bolts of different length. if you can find a selection jus poke them through the holes in the water pump, if you can get about 10-15mm [may get more, measure depth of hole] of bolt to screw into head on each one she should be right
cheers,,got some on order from renault now,, precautionary measure
how much were they from reno then?
i got loads of stainless pump bolts at home
all the correct lengths to
i bought some long ones and just stuck a screw driver in to measure the depth before chopping off the ends..
i needed nearly all of them as there was alot of snapping took great care to remove the bolt shafts from the head. it was the first job i ever did on my gtt and without a doubt the biggest pain in the ar5e due to me being unskilled with the spanners..
well renault said there a 5 bolts but cgb motorsport sell 7 for 3.99
renault want 1.50 a bolt
