Torque settings
Hi guys done a search on here found some info on cylinder head bolt torque's.
I have a Uprated blue headgasket & bolts from CGB.
Should I follow the long route of running for 20mins etc or tighten to 80nm and leave like I have read.
Need to know so I can decide of the torque wrench I have is upto the job
Cheers Guys,
Mike
Re: Torque settings
I'd tightnen and run the bitch, then slacken and retighten the ****ers.
Remember to double check yer valve clearances also
Re: Torque settings
Cheers for the advice pal!
Yeh, I defo have to do the clearances!
Re: Torque settings
you might want to read what ARP says about tightening bolts
http://www.arp-bolts.com/Tech/TechInstall.html
it's not as simple as 'yeah mate, whack it up to 80'
Member
Re: Torque settings
make sure the engine is off at least 5 hours(stone cold) or u might overstretch the bolts!!
