Looking for a pair of wheel spacers to space the rear out to match the front
Gary for the cost of decent hubcentric spacers could you not just source a clio valver rear beam? Valver parts are cheap matey compared to gtt used parts
I could but there's a lot of extra work involved, was just thinking of a quick fix really. Seen 10mm spacers for £10 May just buy 2 sets and long bolts
Also don't they tend to seize up
Re-bleed brake system swap calipers, disc's over and brake lines if needed and then bolt back on with clio beam Would be better than spacer's Gary.
Only ones owend by Chris and the fecking torsion bar has been smacked in wrong way with no lube and rusted solid, no amount of heat, lube or force could get the fecker out I tried to push the stuck side out with strong land rover bottle jacket and fecker wasn't having it it was bending but just wouldn't budge bearing end. And I used alot of lube
