Results 1 to 4 of 4
    Non-member GaryS's Avatar
    Fleet, Hampshire
    Vauxhall vivaro van broke
    Its a 56 plate 2.0 cdti model.
    I just stopped running and i managed to pull over, i know its a fuel problem as i had a quick look, in the bay there is like a little hand pump thing, with my work mate turning the key and me pumping it ran untill i stopped pumping. I had to call the AA out and his computer said its the fuel pressure regulator on the rail. I got towed home
    So what i want to know, is it a hard or pain in the arse job? or expensive?
    I was just about to sell the van and it broke down, good job it wasnt a test drive
    Cheers for any help people.
    Motech Tony Walker's Avatar
    Sep 2005
    Parkgate Cheshire
    Re: Vauxhall vivaro van broke
    The air filter housing rubs on the fuel reg loom and cuts it out. 2 min fix if its that. really really really common.
    Sep 2005
    Parkgate Cheshire
    sorry presumed it was the 1.9
    Dec 2011
    Rail is easy enough to get to at back of engine i havent had a problem with that before check for air leaks on fuel system
