Page 1 of 2 12 LastLast
Results 1 to 50 of 73
    Non-member SCHWARTZ's Avatar
    Wallington south london
    megasquirt
    Well it finally runs
    just got my b18ft running on megasquirt, is there anyone here who can tune/ live map a megasquirt ecu or has experience using tuner studio as i have no idea where to start
    Re: megasquirt
    just got my b18ft running on megasquirt, is there anyone here who can tune/ live map a megasquirt ecu or has experience using tuner studio as i have no idea where to start.
    Gary well done matey
    Re: megasquirt
    cheers james, looks like it was just the ****e renault tdc sensor giving me probs changed it to one of scoffs and it fired straight away, if only i had done that sooner
    Just need it tuned now
    Apr 2011
    Netherlands
    Re: megasquirt
    Take a look on diyautotune, extraefi.co.uk, msextra.com etc.
    Or else why don't you go to Scoff and get it done properly the first time
    Apr 2011
    Netherlands
    Re: megasquirt
    What is your setup exactly? Did you build the MS yourself or did you buy it pre-built?
    I want to make MS in my original ecu case (f7)
    Re: megasquirt
    Lol told you it would be tdc sensor
    Have you tried the map i gave you? Should be ok to get you mobile and some boost action you have afr so can watch fueling is ok
    Re: megasquirt
    bought the ecu built, added launch control(dont know if it works yet) added a knock-tek box to the ecu and a few other little other bits. tacho output still wont work but il sort it.
    I cut up the old volvo loom and used the plugs for the sensors and wired them to the short loom for the ecu.
    Re: megasquirt
    Quote Originally Posted by JTEC View Post
    yes matey using that map but it seems a bit rich at idle and dosnt really want to start you have to give it some throttle and nurse it off or it will stall.
    I havnt let it warm up completly so it may get better when warm and the enrichment needs a bit of tuning but i dont know.
    Re: megasquirt
    I have made a small datalog of the car running for about 1min anyone know how i can post it up for people to look at to see what they think of it to see if it looks about right
    Apr 2011
    Netherlands
    Re: megasquirt
    Do you know if your board has any extra options?
    Like VR conditioner for instance?
    Your flywheel is also renix 44-2-2 or is the volvo flywheel different?
    Re: megasquirt
    dont know what you mean by vr conditioner but its a ms1 v3 ecu with the vr sensor directly wired to it.
    Re: megasquirt
    standard volvo 215mm flywheel 60-2pattern
    Apr 2011
    Netherlands
    Re: megasquirt
    Vr conditioner is a seperate board which plugs into the main board to strengthen the signal.
    But by the reading of it with Scoff's sensor it works
    Does the idle afr meet it's target when warm? If so maybe your wue is too high.
    But beleive me mate, have a read at the websites above and you'll be able to set yourself a good base setup!
    Re: megasquirt
    oh ok no separate board and works fine using scoffs vr sensor.
    I have been sent a decent base map but it needs fine tuning for my engine so really need someone with a better knowledge of me to get the most i can out of it.
    Re: megasquirt
    :quote: Does the idle afr meet it's target when warm? If so maybe your wue is too high. :quote:
    I havnt let the engine warm up properly yet to find out. what do you mean by "wue"?
    Apr 2011
    Netherlands
    Re: megasquirt
    Warm up enrichement. Maybe if the ve table is set correctly but the wue is set too high it will run far too rich during warm-up.
    But seriously, have a read at extraefi.co.uk and just follow the steps.
    The initial settings and first startup are described step by step...
    Re: megasquirt
    Cheers matey il have a good read up on it. It is a map tuned for my enging basicly my setup so won't be that far out so like you say maybe just the wue that needs tuning then.
    Re: megasquirt
    Also sorted out the ms shadow dash and shadow logger so can view and log on the phone when the laptop isn't really needed anymore.
    Apr 2011
    Netherlands
    Re: megasquirt
    Get it warmed up first. If you have the current firmware wue is a percentage of the normal map.
    So if you go messing with the wue now you'll probably mess it up when tuning the ve table.
    Re: megasquirt
    Ok I havnt Changed anything yet as I have no idea about tuning the ve tables.
    Re: megasquirt
    So now its running is it only the be tables I have to play with when its warm. Then when I'm happy there I can do the cold start and warm up enrichment then. If so seems quite simple
    Apr 2011
    Netherlands
    Re: megasquirt
    Indeed, however cold start and wue is the same thing.
    You could shut down wue too to be sure you're only tuning the ve
    Re: megasquirt
    Yeah looked like it was off and it is a percentage but it was silly rich. Think the throttle needs adjusting as it ticks over at 600rpm so may be able to lean idle out a bit with that.
    Apr 2011
    Netherlands
    Re: megasquirt
    cheers matey have had a good read of that still need to read it a few more times before it all goes in
    looks like im nearly there though
    Apr 2011
    Netherlands
    Re: megasquirt
    By the answers it sounds like i know it all but tbh all i know is learnt from reading on the net
    Re: megasquirt
    well youre doing better than me and have been a great help
    I have been reading those sites and there is a lot to take in but its only fine tuning to get it run smoothly.
    Apr 2011
    Netherlands
    Re: megasquirt
    A good basemap is 50% of the work.
    Member Woznaldo's Avatar
    Canberra, Australia
    Re: megasquirt
    Always good to hear another EFI car is up and running. I'm still having spark issues?
    Apr 2011
    Netherlands
    Re: megasquirt
    it has just come in my mind that you don't want to change idle fuel too much. if it's far out try playing with the req_fuel first.
    the chance will be big you finally have it idling good and the rest of the ve table is too rich too.
    Re: megasquirt
    Yeah I have made a few notes of what I have read looks like req fuel adds a percentage to the whole map, but I never let mine warm up fully so didn't change anything. Hopefully il be able to do some tuning wed night so il report back.
    Re: megasquirt
    Are you using standard vr sensor? If so do away with it and fit one of scoffs ones I was getting a poor cranking signal with standard One. Have you turned the pots fully counter clockwise? If you're using standard coil you need to go straight to coil and do away with the plug on the bracket or you'll need to wire in a pull up resistor for it.
    Canberra, Australia
    Re: megasquirt
    I'm already using one of Scoffs VR Sensors but I'm running EDIS. I know that the current trend is to directly run the coil from MS but, I want to get the EDIS set up running first.
    Re: megasquirt
    If ur using edis it will be completely different so ignore what I just said
    Re: megasquirt
    got the engine idling well by upping the req fuel then dropping it when warm. main thing i noticed is that the afr gauge will read something like 13afr and the megasquirt will show 12afr I have tried a few of the settings in tunerstudio for what lambada sensor i have (innovate lc-1) and still isnt right
    Apr 2011
    Netherlands
    Re: megasquirt
    you can calibrate it somewhere, don't know how atm but it's possible.
    beleive the innovate though!
    Re: megasquirt
    I have been going by the innovate gauge only prob is that i think as the megasquirt thinks its different to what it is so it injects a different amount of fuel. I have asked same question on msextra so hopefully they will know what to do.
    Apr 2011
    Netherlands
    Re: megasquirt
    it won't if you don't have EGO correction on
    Re: megasquirt
    Ah is that the adjustment to account for the time taken for the gas to get to the Kannada? If so I havnt touched that, il have a fiddle with it when I get some more tome to play cars
    Apr 2011
    Netherlands
    Re: megasquirt
    No, EGO (exhaust gas oxygen) correction is just like the normal lambda does only then for the complete range of load/revs.
  41. #41
    Re: megasquirt
    Ah ok il have a look at it.
  42. #42
    Re: megasquirt
    right i have the spark map tuned ok but when the engine is idling the dot on the map will sit where i want it at 10deg but the gauge in tunerstudio will read 20 odd deg Does this mean my timing is out? If so is there something on megasquirt that can account for this or is it a case of me moving the tdc sensor along a bit? or drop the whole map 9-10 deg and try to remember they dont match up?
  43. #43
    Re: megasquirt
    In spark settings, the fixed degree is -10 if this was -20.
    would this sort the problem? or is it completely unrelated?
  44. #44
    Re: megasquirt
    ok tried that and tuner studio wouldn't let me so cant be that.
  45. #45
    Re: megasquirt
    all sorted now
    timing was a million miles out Ran at a fixed 10 degrees and using a timing light my mark at tdc was nowhere near visible through the gearbox casing. ended up changing the triggerangle from 60 to 39
    sits lovely at 10 deg now at a nice 900rmp and all the gauges now match up
  46. #46
    Apr 2011
    Netherlands
    Re: megasquirt
    How's it going atm?
    I almost have my 9 running on MS now, only need to sort the trigger. I don't get any signal at all
  47. #47
    Re: megasquirt
    Yeah running well just needs the maps sorting out a bit more but can't drive it yet so can't map it under load until I mot and insure it.
    Have you wound the two pots out fully clockwise? What vr sensor are you using? How is it wired to the ms?
    I will post up a pix when I can get to it of a wiring diagram that I have edited to make it easier to understand.
  48. #48
    Apr 2011
    Netherlands
    Re: megasquirt
    It's counter clockwise but yeah i have them fully ccw, it's just something that's not right, i'm sure!
    I'm using the original renault item, i know it's not perfect but atleast o should get some signal!
  49. #49
    Re: megasquirt
    That's what I ment that's what I thought about it but changed it for a scoff one and fired up first time.
  50. #50
    Re: megasquirt
    Try fitting it lower for a start.
