Results 1 to 17 of 17
    Non-member V6 CREW's Avatar
    Nov 2009
    somerset
    wheel spacers
    Hello there!
    I really need help with the off set on the back end of my project! i need huge spacers if you can help?? i have 35mm at the moment but its not even close. My car has the dimma arches on it so help or advise would be much appreciated peeps Picks on my profile.
    Cheers Tel
    Non-member philr5t's Avatar
    Dec 2008
    tadworth
    Re: wheel spacers
    What is the width of the wheel your trying to put on mate
    Nov 2009
    somerset
    Re: wheel spacers
    Hi the wheels are 205-40-17s well the tyres. cheers Tel
    Re: wheel spacers
    Best thing is to change the wheels to bring them out from the car. Even with 35mm spacers its going to cause problems let alone going for anything bigger
    Jul 2009
    lost
    Re: wheel spacers
    Fk do hubcentric spacers. I belive they do up to 60mm. I think demon tweaks sell fk stuff.
    Nov 2009
    somerset
    Re: wheel spacers
    Oh no i hope there is another way the alloys are being refurbed as we speak!!!
    Jul 2009
    lost
    Re: wheel spacers
    I had a mk2 golf on borbet a,s and I had 55mm fk hubcentric spacers.
    Re: wheel spacers
    You won't get spacers out that far without causing damage in bearings very quickly. Not sure about getting a Williams rear beam on it should make it wider but still going to be stuck getting wheels out that far
    Dec 2008
    tadworth
    Re: wheel spacers
    i would say to make it look right with that kit on your wheels need to be a minimum of 9" wide but 10's would probably be better if the wheels you have on there at the mo are only 6.5-7.5" wide they will never look right mate and i for sure would not want to run a massive spacer. Time for some new deep dish 10" rims i think mate
    Non-member benj88's Avatar
    Mar 2010
    Re: wheel spacers
    Would look better on wider wheels with being a dimma kit mate. Some 9'' azevs would look unreal. Just my opinion anyway!
    Mar 2010
    Re: wheel spacers
    Quote Originally Posted by philr5t View Post
    Nov 2009
    somerset
    Re: wheel spacers
    So how much will those deep dish bad boys going to cost???
    I totally agree it will look loads better but judt dont have the cash for a new set inc tyres i bet its a big wedge?!?!
    Re: wheel spacers
    Might be worth searching through the alpine GTA alloys as they will have the wide wheels at the back already. Not sure on costs. Think its like 6.5j front and 8.5j rears
    Dec 2008
    tadworth
    Re: wheel spacers
    Quote Originally Posted by V6 CREW View Post
    take a look on this website mate you may just find something perfect you like a decent set of mint split rims will cost you £1,000+ easy without tyres but you can get copied sets and other brands for a lot less. If you have origional hubs on the 5 then your need something like a 13/14/15 or a 16" rim and i would say 8's or 9's on the front and 10's on the back width, but you will still need 4x100 centres (pcd).
    http://wheel-whores.com/
    phil
    Nov 2009
    somerset
    Re: wheel spacers
    Ok thanks ill take a look. Im a big fan of the clio v6 being a phat motor (and as ive had one see profile) the multi spokes on that in black would be nice. Not sure of width though??? any body know? they might be fatter on the rear end being rear wheel drive too!
    Re: wheel spacers
    They are 5 stud rather than 4 stud unless you want to convert your hubs
    Member Thundercat's Avatar
    Re: wheel spacers
    Back when i had my dimma, i ran with some 16" 8j image wheels found on ebay with 25mm fk hub centric spacers. Keep your eyes open on ebay, think i pay'd about £250 for wheels.
