Results 1 to 3 of 3
    Non-member ioshi_s_golf's Avatar
    Oct 2010
    Manchester/ Bulgaria
    Should be R5, but end up to be Honda
    Hi guys today i bought this honda Civic 1.6 d16a3 120hp. Some info about it
    D16A3
    Compression : 9.5:1
    Power: 88 kW (120 PS; 118 hp) at 5,600 rpm
    Torque: 140 Nm (14.3 kgm, 103 lbft) at 4,800 rpm
    Valvetrain: DOHC 16-valve, four valves per cylinder
    Fuel Control: OBD-0 MPFI
    My plan is to fit turbo, this what i'm wondering should i drop the comp ratio to be safe.
    The turbo what i'm thinking to use is Garrett T4 it's a bit big but will see on the end.
    Compressor Wheel Turbine Wheel
    Inducer Dia. Exducer Dia. Inducer Dia. Exducer Dia.
    48.4mm 81.9mm 74.2mm 58.3mm
    Few pics
    What do you think guys ?
    Dec 2011
    Re: Should be R5, but end up to be Honda
    I think theres a member on here just starting to do a civic turbo conversion i think you can buy a deck to put cylinder head on to drop compression i mite be talking crap
    Oct 2010
    Yeah i'm thinking to put decomp plate to drop the comp ratio.
    I'm thinkin to push it no more than 1 bar with the T4 with 8;1 comp ratio.
