Results 1 to 22 of 22
    Non-member chipis's Avatar
    Feb 2012
    Lithuania
    Oil temperature
    Hello, have installed new radiator without oil cooler/heater option. and now my oil temp rises up only to 60 degrees of celcius, i have installed temp gauge near the stock oil pressure gauge. Is this normal oil temperature in that place? how much oil temperature you are having without oil cooler/heater radiator? shouldnt the oil temperature vary between 90 and 110 celcius?
    Non-member Mart's Avatar
    May 1996
    Pie & mash shop
    Re: Oil temperature
    ~90c is ideal.
    If you're running a remote oil cooler, it's best to have a thermostat in situ as well.
    Feb 2012
    Lithuania
    Re: Oil temperature
    at the moment im not running any oil cooler and it cannot reach necessary oil temperatures
    Non-member car.crash's Avatar
    Aug 2006
    Re: Oil temperature
    How long are you running the engine before you take your reading? It takes the oil a while to fully heat compared to water.
    Also what gauge are you using and where is the sender located.
    Feb 2012
    Lithuania
    Re: Oil temperature
    iim driving an hour or two with many hard pull ups and temperature hardly reaches 60 degrees of celcius. i have installed my temp sender nearby oem oil pressure gauge joint to the block. As i understand c1j engines are too small to heat the oil by them self without oil heater in radiator and thats why factory has made oil heater in the water radiator. now im thinking how to make oil heater with aftermarket coolant radiator
    Aug 2006
    Re: Oil temperature
    I never had a heater on my car, just a oil cooler with a built in thermostat.
    My oil always sat at around 90c.
    Are the ambient temperatures a lot lower in your country?
    Also test your gauge on some boiling water with a thermometer inside aswell to make sure your getting correct readings from the gauge.
    A bad earth can make a gauge read funny.
    Motech Tony Walker's Avatar
    Sep 2005
    Parkgate Cheshire
    Re: Oil temperature
    What have you done with the sandwhich plate and pipes? or are you screwing the filter direct to the block? my oil takes a bit to warm up and sits normally around 60ish celcius, little low but in the winter i put a panel across the cooler to increase the temps. Ideally a thermostat with cooler should be used, i cant understand why its not getting up to more than 60 without a cooler, certainly should do,.
    Re: Oil temperature
    Is your gauge reading correctly? As far as im aware the original rad has an oil cooler built in not a heater?
    Sep 2005
    Parkgate Cheshire
    Re: Oil temperature
    The water heating up in the rad does heat the oil untill the temperatures equalise.
    Feb 2012
    Lithuania
    Re: Oil temperature
    where have you pluged oil temp gauge sender unit? i thought such low temperatures are usual for this kind of engine, i will have to check it in boiling water and its earth as well!
    Dartford
    Re: Oil temperature
    they should normally be in the sump plug..
    Feb 2012
    Lithuania
    Re: Oil temperature
    so i wonder where people are meassuring oil temp and what readings they get in different places?
    Aug 2006
    Re: Oil temperature
    I was measuring mine off the front if the block. Where the triangle plate sits with the 3 bolts. Readings where around 80-90c
    May 1996
    Pie & mash shop
    Re: Oil temperature
    Quote Originally Posted by chipis View Post
    So you have it plumbed o.e (via the radiator), or no cooler whatsoever?
    Dartford
    Re: Oil temperature
    I would say this position would only tell you vapour temps.. Manufacturers (vag) have them in the sump..
    So as I said earlier, in the sump is the best place
    Sep 2005
    Parkgate Cheshire
    Re: Oil temperature
    also the temp of the block is going to be affecting the readings, chances are your oils actually colder than that in the sump, the temp leaving the turbo ideally is best as its this temp you want to know as this is where its likely to be hotest, ive welded a boss in by my oil return pipe to measure it here roughly. sump plug imo just makes a target for speedbumps to rip off and dump your oil
    Re: Oil temperature
    My sensor is soldered into the back of the sump. I have an external oil cooler (with stat) and depending on the weather I see between 100-110c ish.
    Dartford
    Re: Oil temperature
    Yes, obviously it's better getting a fitting welded in the sump, but most people can't be arsed to take it all of so just stick them where the sump plug normally goes (they are actually quite small)..
    Anyway the point I was making is that the best place to read oil temp is in the SUMP
    Sep 2005
    Parkgate Cheshire
    Re: Oil temperature
    Apr 2011
    Re: Oil temperature
    Can I put my oil temperature sender into the sump where the oe oil level used to be, ie at the front by the turbo return pipe. I've put it in here and turned engine by hand and it doesn't hit, but will it be submerged in oil?
    Re: Oil temperature
    I suspect the oil level will be lower than that? The OE level senor is quite long and is angled downwards so it sits in the oil......
    Apr 2011
    Re: Oil temperature
    shame it fits lovely in there, I have got an in line sender housing that I'll have to use then. Where's best to put it, maybe in the oil turbo return pipe?
