Page 1 of 2 12 LastLast
Results 1 to 50 of 54
    Non-member Wallace's Avatar
    herts
    AFR's Carb set up help
    Hi all,
    Just been for a spin in the 5 and its not fueling correctly at all - any help is greatly appreciated
    I'm using an AEM Gauge, the engine is standard and i've turned the boost right down, as the engines got barely 30miles on it since rebuild!
    The carb is standard venturi as far as i can tell...............i had measured it with a vernier but that was ages ago.....so a pointer here would be very helpful
    Carb Spec:
    A/C Jet=100 - Main Jet=120 - 2nd/Enrichment Jet?=125
    I've set the idle which does fluctuate between: 13.6 up to 14.7, but does appear to remain around 13.9 up to 14.2.......and this has been set whilst letting the car warm up, then turned off etc to see if it remains stable, which it kinda does!.................
    But after the car has been run upto temperature,fans kicked in a couple times and more importantly the car be driven!!!! once i stop and leave it to tick over (around 1000rpm) I'm back to afr's of around 12.1 on idle?
    Also, general driving - up to around 3000rpm i hit a flat 10.0 and only moves once i come off throttle completely and it will read around 12.1 again
    I have checked for air leaks with carb cleaner and nothing changes!
    Soooooo what i'm wondering is:
    (1) Whats people opinions on the idle AFR's? - Adjust it again once its been used i assume?
    (2) When we talk of 'Group A' Carbs - where should i be measuring, I know venturi but a little more info please? (i obviously wanna rule this out!)
    (3) To get this reading of 10.0 adjusted or at least moving one way or another!! - Can you offer me some starting points please?
    Non-member casper's Avatar
    Jul 2012
    Re: AFR's Carb set up help
    Hi,my carb is set up for 1bar of boost,just as a test I put a 1.00mm a/c in from a 1.20mm and it cocked the fueling up big time,super rich and not just at high boost,was surprised at just how much of a difference it made
    herts
    Quote Originally Posted by casper View Post
    Cheers
    Been 1 of my considerations as the original carb (which i assume to be factory standard) has a 120 in it.......
    I've thought also, looking at your previous thread, that accerlater pump may be adjusted incorrectly too....
    The joys
    Jul 2012
    Think the a/c was 1.25mm as standard.I no every engine is different but your jets would fuel 20psi on my car.
    herts
    20psi
    I'm gonna have a crack at it again tmrw- can anyone shed some light on the accelerator pump adjustment?
    Dartford
    Quote Originally Posted by Wallace View Post
    20psi
    Use a 5mm drill bit to set the acc pump.
    20psi
    Smooth end of 5mm drill bit let it rest against the slot in the carb and let throttle butterfly rest against it then adjsut the bolt / spring so that it is pushing just pushing the pump jet in fully at this point
    Jul 2012
    What if the acc jet is putting too much fuel in even after setting with a 5mm drill bit?Is it just a case of shortening the stroke on the pump arm?
    herts
    Errrrrrrr
    herts
    Quote Originally Posted by JTEC View Post
    Cheers James
    I kinda get the idea..............this will not be helping either way as i've never set it up properly before now
    hampshire
    if ive read this wrong i apologise, but just in case
    the boost enrichment is a fixed bush, not a jet. if the removeable jet in your enrichment block is a 125 a/c type jet. that'll give you your 10s put it back to 100
    Dublin/Ireland
    check the carb at idle and part open throttle that there is no fuel dripping from the aux venturi!
    herts
    Quote Originally Posted by fishead View Post
    Cheers Tony - I'll do this tmrw
    It wont be you reading it wrong mate, its gonna be me being a numpty
    all gotta learn
    herts
    I'm sorry Michael but can you explain that in idiots terms - you've just enlightened me that theres even an 'aux venturi'
    Thank you
    Jul 2012
    Hi Wallace, hope you don't think I'm hijacking your thread but this may help us both.Today I noticed the jet of fuel coming from the acc jet was almost going straight onto the throttle plate,don't think this is correct,thought it was supposed to hit the wall or center part first,could someone advise please.
    herts
    Crack on mate,its all learning
    Dublin/Ireland
    the auxiliary venturi is where the discharge nozzle is, right in the middle of the main venturi! when u open it up"u,ll see the fuel mixture coming out! it should,nt drip at idle or just off idle....if it does its more than likely ur needle and jet...dirty or worn! with regards to the acc.pump jet i think squirting towards the throttle plate is correct!
    Non-member GT Josh's Avatar
    Mar 2012
    Boosting
    Squirting is correct mate. Usually rich afrs are when that either drips or floods so to speak. My brother had a similar issue. It ended up being one of the enrichment triangles on the side of the carb. If mine idles between 13-14 and is good on boost and cruise I don't bother.
    Jul 2012
    Don't no where I pulled that one from then.
    herts
    Thanks Michael that's really helpful
    herts
    At idle, nothing coming through.....
    At even the slightest bit of throttle (perhaps not even 5mm movement) a constant stream of fuel and that is stream not 'mist' or 'squirt'!!!
    So am i to assume this isnt right?
    I have changed the discharge nozzle with another that i have, and still the same
    herts
    Including the above.............i've also changed the jets over as above.
    The car now idles very smoothly and i'm getting good rreadings around 14.1
    So I'm now spec'd with: a/c=125 & 1st Stage=100
    But the afr's are still 10.0 with a minor change now to 10.5 and maybe 10.7, this is all taken at part throttle around 2500-3000rpm......
    Can you offer me any further advice please?
    Cheers
    Jul 2012
    Have you set the acc pump.?measured your main with a drill bit?
    herts
    Yes.............to a point! i've adjusted it today numerous times, and also either fully in or out doesn't make any difference
    Convienced i'm not setting it correctly,still not overly sure where the drill comes into play COCK - Can you explain in idiots terms?
    I'll also check the gasket/diaphram isn't faulty tmrw
    I haven't actually measured the main with a drill - but will tmrw
    herts
    https://www.rtoc.org/boards/showthread.php?t=460
    Having re-read this article, its obviously gonna be a case of trial and error
    I know James has tried explaining the acc pump set-up, but i'm just not gettting it
    If you guys could break it down to numpty talk for me, then i'll adjust it again tmrw and just keep playing with jets till i hopefully get the right kinda readings
    Thanks again...............off to work now so roll on tmrw
    Jul 2012
    Hi mate,just Google solex dis and look at the first few links,plenty of diagrams that explain it.You might be better off waiting till your engines run in,then fuel for the boost your planning on running,get your wot sorted first then take it from there.
    herts
    I'll have google now........
    With regards to setting it for WOT, I obviously wanna get it set right for part throttle because I've 500 odd miles to bed the eingine in,and its not gonna do it any favours the ways its fueling at the minute
    Jul 2012
    If your reving it to 3k with a t2,is that on boost?What's the afrs at say 60mph in 5th.?
    herts
    Only just hitting boost really, it depends how its driven-and I'm drivimg it like a grandad cause the boost is turned right down for the engine to bed in
    I've not even gone over 40mph yet bearing in mind its not MOT'd I'm just pushing my luck on a private road
    herts
    Jul 2012
    Non-member s3irios's Avatar
    Jun 2012
    Greece
    I had/have same issue, i even strted a thread with no success. I have same lame ultra rich 10s' readings too. I tried what gtjosh if i remember correctly said changing the triangle part (enrichment chamber) with no success. Carb has been cleaned numerous times, it looks spot on too. Can't really address the issue anymore. It's annoying as hell, it's expensive as hell (consuming that much fuel at little or no boost-wtf?) AND is making the car actually slower. In between gears and at low-middle revs the car is laggish like hell and really slow compared to how it was some years ago before the problem pops up.
    Yes i know i didn't exactly give any solution, but wanted to inform you that there are others out there with same problem
    Ohh almost forgot . The ultra rich afr problem lead to my piston rings going off. Now except the excessivce fuel consumption i have excessive OIL consumption too
    Non-member StuHERTS's Avatar
    Sep 2012
    Congrats on your MOT pass Wallace
    Thought id get in first lol
    herts
    Quote Originally Posted by s3irios View Post
    Corrr mate unhappy days to say the least
    I cant offer any solutions myself yet - but, i think it is a 3 stage attack for me........
    (1) Adjusting the accelerator pump - trial and error i suppose and in effect ignoring the 5mm setting
    (2) Reducing the main jet
    (3) Enlarging the a/c jet
    If i have success then i will of course update this thread and hopefully help you out too
    herts
    Quote Originally Posted by StuHERTS View Post
    Yeeeeeeeeeeeeeeeeeeeeeeah boi
    Not that i'm bothered or anything
    At least now i can sort the fueling out and give it a good trial rather than - just past your road-turn round-just past my road-turn round-just past yours-just past mine-just past yours-just past mine
    Motech Tony Walker's Avatar
    Sep 2005
    Parkgate Cheshire
    Prob best to try a spare carb then swap and change bits and see what cures it.
    It may be a flaw in the carb body we havent yet got involved enough to cure. i wouldnt try reducing main jets and changing air correctors from standard. they are those values for a reason and should fuel correctly with those jets, if it doesnt then theres a problem.
    Sep 2005
    Parkgate Cheshire
    Either way...... good luck
    herts
    Cheers Tony.........
    I'm gonna have a play about anyway, with afr gauge and more importantly not driving it like an idiot, it'll be good learning for me
    I have however got a spare carb so tmrw will really get involved and see if i can get it fueling well
    As for now though, as you'll see above its past its MOT Beer o'clock
    Jun 2012
    Greece
    Did all 3 steps you mentioned nada. Well thy might work for you but they sure didn't change anything to me. A spare carb is the best solution.
    herts
    Right ok.......well if you've tried and its not worked then the spare carb will be my first step!
  41. #41
    herts
    Sooooooo, I fitted the original carb and the afr's changed COMPLETELY!!!!!
    Basically far better, and its given me a better base to work from........
    As far as i'm concerned the old carb must be 'faulty' for what ever reason, i will eventually get to the bottom of it by measuring the bushes and checking seals etc etc etc.................and i'll let you know what i find
    Once ive re-adjusted the acc pump again (been fiddling with it to see the differences!) and given the carb yet ANOTHER clean.........as i've got issues with the idle jet getting blocked by swaf, but once i've cured that i be a happy boy
  42. #42
    Sep 2012
    Thats good news mate!
    Im about today if you need a hand.
  43. #43
    Sep 2005
    Parkgate Cheshire
    u
  44. #44
    herts
    Seem to have reached the goal,as such.......
    Done a fair few miles today - I think alot of it, is learning how the carb fuels and behaves, which is a bit of fine science for a newb
    Idles beautifully now - cruising i'm seeing anything from 12.0 - 15.9 but VERY much dependant on the gear im in and the amount of throttle (obviously!) - but over run has improved and will mostly remain around idle afr's (13.8-14.2) but can occasionally sink to 16.0-17.0 etc!
    But all in all very happy, got the afrs i should so i can now get some miles on the engine and then start playing with the boost and then the fueling all over agin
    THANK YOU ALL FOR THE INPUT
  45. #45
    Non-member Jonny5's Avatar
    Sleaford
    Good news mate, lovely motor too
  46. #46
    herts
    Quote Originally Posted by Jonny5 View Post
    Cheers
  47. #47
    Sep 2005
    Parkgate Cheshire
    Sounds about right now, it's a bit of cat and mouse trying to keep up speed and efficiency :-) mine works best about 70 in 5th :-) luckily lol
  48. #48
    That's carbs for you!
  49. #49
    herts
    It has completely shown me why the cars got a bad rep in the old days,for the head gasket going,obviously as result of things not being set-up right!
    With the afr gauge, it shows they are so clearly vunerable to poor fueling, which obviously then leads to a world of pain and expense............
    I never thought that the carb would be so changable to be honest,and lack consistency..........
  50. #50
    Sep 2012
    Im glad you've got it sorted mate..
    because you can then do mine!
    LOL
    Hoping to order my AFR within the next 2 weeks..
    Anyone want to buy a Scott Scale 29er 2012 Mountain Bike?
