Results 1 to 23 of 23
    Jun 2012
    pipe in to sump?
    Right so my sump was nakard, i got one off a friend who had one lying around, spent all day removing mine and fitting the new one then went to put tge pipe on that goes from the turbo to the sump and it doesnt fit so grabbed my old sump and the fitting on the sump is a differant size, the sump i had on was a baffled sump and ive just put an ordinary stock sump on, anyone know a reason why these are differant? And does it make that much differance having a baffled sump seen as the car does not go on the track?
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    Re: pipe in to sump?
    Phase 1 and 2 are different diameters, I think the phase 1 is smaller.
    Jun 2012
    Ohhh so that would suggest my old sump was off a ph1 thn lol. wts the pipe for? is it just a return from turbo?
    The pipe is the oil return off the turbo.
    Jun 2012
    I thought it would be. so fitting a larger diameter pipe isnt going to cause a problem is it? Obviously i would need the larger fitting for the pipe to go on the turbo but thats easier than changing the sump again lol rite bitch of a job they are haha
    Larger pipe wont cause a problem.
    Jun 2012
    Cheers pal. didnt think it would do but makes it easier wen sum1 else says it haha
    Bigger ph2 pipe is better mate ill be honest
    Jun 2012
    cool. i can just fit any pipe as long as its for oil cant it or does it have to be certain stuff?
    Ideally you need a fluoro lined silicone hose but a normal silicone bend should work OK
    Non-member TNT ANDY's Avatar
    Are there any problems doing this the other way round?
    I'm putting a baffled sump on mine which has the smaller pipe? I was going to sleeve the smaller pipe so that my bigger pipe fits over it.
    I have the baffled sump with the smaller pipe on mine, have used a reducing 90deg elbow with no problems be better fitting the proper pipe for a tenner to reduce the chance of leaking though.
    Thanks for that fella - e-bay Ahoy
    Trader
    GT Turbo Spares co.uk
    South East Regional Rep
    phase i 16 v turbo's Avatar
    Jan 2001
    Morden
    Renault enlarged the oil return on the Phase 2 there must be a reason for doing so.
    Non-member Chunk's Avatar
    Oct 2010
    Loughborough
    I can only guess to prevent the oil backing up
    Non-member s3irios's Avatar
    Jun 2012
    Greece
    Nah it's probably to help oil drain faster and not stay in the hose, thus toping and getting past the seals on the turbo.
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    Quote Originally Posted by Chunk View Post
    Quote Originally Posted by s3irios View Post
    Oct 2010
    Loughborough
    Jun 2012
    I was thinkin the same must be to get the cooler oil in quicker. they wunt of changed the size on the p2 unless they proved it to better
    Cutting disk and welder on stand-by
    Trader
    Jan 2001
    Morden
    I have Phase 1 and Phase 2 baffled sumps in the unit. Just not had a change to get them listed on the website.
    I wouldnt bother mate, you wont need to change it.
    Off standby
