Results 1 to 12 of 12
    Paint Codes
    Right then peeps, since there seem to be a few more of us with 9's and 11's, I figure we could do getting details for these cars built up such as paint codes, part numbers stuff like that.
    So here's my start, my R9 GTL has a paint code of 620 which is a red of some form which doesn't exist anymore, 620 is apparently now a silver/grey colour.
    What have others got?
    Tipton
    Re: Paint Codes
    620 has been silver from before your 9 came into existence
    http://www.r5gordini.co.uk/mediawiki...olors78-08.jpg
    Re: Paint Codes
    Ah c**k, does this mean I've got a hooky motor or did some lazy frenchie put the wrong number on the plate :/
    I'm guessing the later
    Tipton
    Re: Paint Codes
    the mk1 5's used a shonky sticker or a painted stencil on the inner wing. - are you sure you're looking at the right thing?
    Norwich
    Re: Paint Codes
    Good idea Olski, there's few part no.s in this bit already, be handy to know what you can still get from renault these days. I have found some stuff on ebay from factors, old stock etc
    Re: Paint Codes
    I looked on the oval plate same as a Gtt I thought
    Re: Paint Codes
    And we could also build a list of parts off of other cars that would fit parts that are no longer available, such as rear dampers off of a mk2 Clio will fit if you drill out the bottom bushes to 14.02mm
    Re: Paint Codes
    Continuing the list of parts for 9's and 11's
    I've had to replace the wishbones on the 9 as they are as straight as Graham Nortan.
    Renault want 150+vat each
    Motorspares 46quid for the pair
    Anti roll bar bushes, mine has a 23mm bar, poly jobs for a clio 172 will fit perfectly, inners look like 172 items might fit, got a mate stripping a 172 so ill have a closer look
    Norwich
    Re: Paint Codes
    Result on the wishbones Olski, still trying to source outter anti roll bar bushes for the 11, let alone inners, MOT tomorrow afternoon on project 'DOOD'
    Re: Paint Codes
    My poly 172 outers turned up yesterday, perfect fit here's hoping the inners will be good too.
    Good luck fella, let me know how you get on
    Non-member JP Racing's Avatar
    Apr 2009
    Ely
    Re: Paint Codes
    Oli I'm pretty sure that Renault didn't do many reds and it should be the same red as my 5 Carmen red worth a try paint code 348
    Re: Paint Codes
    Quote Originally Posted by JP Racing View Post
    Already got the number mate, it's 705, thanks to Paul B
