Huge clearout of Clio parts - CHEAP!
I've finally managed to empty all my boxes of spares and catalog what I have available. I need to get rid of all of this so i'll be selling cheap!
Postage is available but collection is much preferred on heavy items.
I'll let the pictures do the talking - a full list of parts is available at the bottom. Have a look and shout if there's anything you need.
List of parts:
Glovebox lid - £2
Airbox support bracket x2 - £1
Ph1 fuel cap in black - £2
PAS cap - £1
ECU wiring bracket - £Free
Radiator support - £Free
Ph1 speaker grilles - £5
Ph2 speaker grilles - £2.50
Headlight adjuster panel (dirty just needs a wipe) - £1
Clarke impact gun - £10 (Charger is broken)
Spark plug tray x 3 - £2 each
Fog light wiring loom - £2
Drivers side hub x 2 - £2 each
Header tank & cap - £2
Inlet manifold plastic cover - £1
Genuine renault throttle cable - £2
ABS Master cylinder - £2
Drivers side indicator - £2
Ph2 steering wheel cap - £1
F7P head complete with cams, carriers, valves - £10
F7P head complete with cams, carriers, belt valves - £5
Full set of Ph2 door moulds (one damaged as shown) - £5
Ph1 front door moulds - £5
K&N air filter - £2
Throttle body - £2
Fuel rail & injectors - £5
Thermostat housing x 2 - £2 each
Map sensor including pipework - £2
F7P bottom ends, one on 90k (dirty, uncleaned), other mileage unknown but cleaned and in excellent condition - £10 each
Wishbone brake coolers x 5 - £1 each
Original set of speakers - £2 for all
Original stereo steering wheel controls - £1
Exhaust 'U' bend (one from Clio 16v, one from low spec) - £5 each
Oil pressure sensor - £2
Renault 19 gearbox mount rubber x 2 - £2 each
Engine wiring loom (missing a couple of plugs) - £5
Inlet manifold end bracket/support - £1 each
Gearbox mount (missing rubbers) x 2 - £Free
172 gearbox battery tray including rubber - £2
Lifting eye in white - £1
PAS pump pipe x 2 - £1 each
Standard gearbox release arm - £1 each
172 gearbox release arm x 2 - £10 each
Vac pipe from head - £1 each
PAS pulley x 2 - £1 each
Cam pulley cover x 2 - £2 each
Top radiator hose - £1
Fog light wiring cover - £50p
Brand new distributor cap - £1
Random auxilliary belts (brand new) - £1 each
Standard orange side repeaters - £Free
Gearbox mount support bracket, powdercoated in black - £10
PAS reservoir - £1
Alternator mounting bolt including nut - £1
Head unit flip cover - £1
F7P exhaust manifold support bracket x 2 - £1
Gearbox rear dogbone mount bracket - £1
Plastic Ph2 clover wheel caps - £1 each
Inlet manifold support brackets - £50p each
Front block ancillary mount bracket x 2 - £1 each
Ash tray - £50p
Front bumper mounting bracket from middle -£50p
Map sensor - £50p
Master cylinder bracket x 2 - £50p
Lambda sensor heatsheild x 2 - £1
F7P/R flywheel - £2
Gearbox to dogbone mount support bracket - £2
Fuel line heatshield x 3 - £50p each
2 x interior door handles, no cracks - £1 for both
2 x wishbones (not sure what they are from) - £Free
Spark plug tray cover (F16ie) - £1 each
Starter motor heatsheild in good condition - £1
Brake servo pipe - £1
Crank pulley - £1
Fuel line plastic trunking - £50p
Standard undrilled airbox including pipercross panel filter - £10
Inlet manifold/exhaust manifold gaskets - £1 for both
PAS rack - £FREE (Ideal if you want to pack full of grease as green pipes are damaged)
Driveshafts, £1 each (some need new boots but otherwise good)
Parcel shelf (good condition) - £1
Ancillary bracket including tensioner x 2 - £2 each. One has good tensioner, other is rough. Free pas pump on one.
Starter motor x 7 - £5 each. Some F7P, some williams, some random. All will work on F7P/R engine.
Standard fitment oil cooler including thread for block and rubber pipe, excellent condition - £10
Polished cam cover with 432 painted inlay, including lead tray and f16ie cover with securing screws - £40
Plastic cambelt covers, different types - £2 each
Top engine mount cover - £1
Standard Clio 16v battery tray - £1 each
F7P exhaust manifold - £1
I think that covers most of it - if there's anything you see that you want just drop me a message.
Anything not sold at the end of the month will be binned.
Willing to discuss selling as a job lot for a cheap price. Open to offers.
All parts located in Birstall, Leicestershire.
Re: Huge clearout of Clio parts - CHEAP!
Hi,
Can i have the engine wiring loom, ecu bracket and fly wheel please. Might take the impact gun to mate, im over in cropston now mate so can pop over in about 6 minutes
Sorry i've only just seen this.
The impact gun has gone but the rest of the bits are still available.
I'm around this evening if you want to come and collect?
