how to modify you engine 101. the bits you need all here in one go
If you want more power from standard here are the bits you need all in one place
Double capacity intercooler
T25 front end, 360 bearing turbo in good condition no play front to back from what I can feel.
Turbo oil banjo pipe thingee (technical term) with oil temperature sensor.
AFR gauge with all the wIres and the downpipe with the welded screw bit.
Oil cooler with all the bit to screw in (some grinding will need to be done to block to fit)
Carb that was set up for my car - every car is different but this ran well.
I have an upgraded fuel pump (still attached but can get it off easy enough)
Nice job lot- am open to offers here before it goes on eBay. Ideally want it sold as a job lot.
Currently in Nottingham for this weekend then the bIts will be back in London
