waterpump
Can't take the squeeking from my water pump anymore!
Any tips / hints when fitting a water pump?
Committee, NW Regional Rep
Re: waterpump
Buy some new stainless steel bolts for re-fitting the new one.
Look-Out
Re: waterpump
Be careful when undoing the bolts......you can pretty much guarantree that one will shear.......you should be able to use mole grips on the offending bolt once the pump is off though. You may be lucky however and not snap one
Replace will stainless, and some copper slip
