Results 1 to 8 of 8
    Non-member Hi 5's Avatar
    wakefield
    Helix paddle clutch and lightened flywheel
    Remanufactered helix clutch 4 paddle with helix cover respung to 300 lbft and lightened flywheel as good as new £200 contact me on 07968069723
    Re: Helix paddle clutch and lightened flywheel
    Was this used with your C1J engine, running adaptronic?
    Is it 200mm flywheel?
    Might be interested if it works fine with that as, will be using on F7P turbo.
    wakefield
    Yes it is pal just had it redone repaded and check etc
    Committee Member
    North West Regional Area Rep
    BluntyR5GTT's Avatar
    Nov 2009
    Stoke-on-Trent
    bloody hell fella if i hadnt got spend on sorting the bodywork etc on my car id of snapped this up off you, as my clutch aint up to the job now
    You going to ND?
    If not can sort out for postage to where my car is at the moment
    wakefield
    Yes pal going to nd day
    Will sort it out with you up there
    Cheers
    wakefield
    Sorted no problem
