Results 1 to 4 of 4
    Dec 2011
    Actuator Help
    Hi,
    I have just fitted a Rover tomcat 220 turbo to my R5 (T25 I believe). What actuator will fit onto this turbo? I want an uprated actuator with the preload at about 15psi, have seen the below on eBay, will this work? what other options do I have?
    Matey in Brighton has the same turbo as me and he has a new actuator that he bought and fitted but I dont the dudes name?!?!?! PM me if you know the chap I mean!
    http://www.ebay.co.uk/itm/FMACROV2-F...item4164a908be
    Committee Member
    North West Regional Area Rep
    BluntyR5GTT's Avatar
    Nov 2009
    Stoke-on-Trent
    Re: Actuator Help
    hi mate get a genuine garrett -31 on there, you can sometimes pick 2nd hand ones off ebay (rs turbo,cosworth) might just need make a bracket up to mount it on then.
    Feb 2011
    Down South
    Re: Actuator Help
    Pm ed ya one on eBay now will work well but may need small cut and weld but is still adjustable to fit the bracket
    Dec 2011
    Re: Actuator Help
    Many thanks boys...
    Markey Mark will tell you I am notorious for buying things that are non-standard, then compain when they dont fit , so I thought I would change that!
    Guess i'll just have to be paitent and keep looking
