Results 1 to 9 of 9
    Banned
    Feb 2011
    Brake caliper.what other cars have the same one as 5
    As little says.need drivers side front.what othe French cars use same caliper?
    Thanks peeps.
    Norwich
    Re: Brake caliper.what other cars have the same one as 5
    Think Pug 205 GTI's are same, believe there are 2 types, bendix, or girling
    Non-member Coops's Avatar
    clio RSi use same setup as well, and technically Mk1 16v and Williams use the same caliper, just a different carrier and disc.
    as mentioned above though there are two types and the caliper matches to the carrier for each type iirc
    These are all front Griling Calipers
    Citroen ZX 1.4 1.6 1.8 2.0
    Pug 205 1.9
    Pug 309 1.6
    Pug 309 1.9 gti
    Renault 11 turbo
    Renault 19 1.7
    Renault 19 1.8
    Renault 19 1.9 td and d
    Renault 21 1.7
    Renault 9 turbo
    Renault clio 1.2 98-05
    Renault clio 1.4 91-05
    Renault clio 1.5 DCi
    Renault 1.6 16v 98-05
    Renault clio 1.8 16v 91-96
    Renault Clio 1.8 8v 91-97
    Renault clio 1.9 diesel 91-01
    Renault Clio Williams 91-95
    Clio campus 1.2 05-08
    Renault clio campus 1.5 DCi
    Renault Megane 1.4 1.6 1.8 96 - 02
    Renault Megane 1.9 DCi 00-02
    Renault Megane 1.9 TD 96-98
    Renault Megane 2.0 8v 96-99
    Renault Scenic 1.4 99-03
    Renault Scenic 1.6 97-03
    Renault Twingo 1.2 07-
    Hope that helps
    Banned
    Feb 2011
    Lots then
    Cheers
    rofl, list of win
    Citroen ZX 1.4 1.6 1.8 2.0.......
    Is there a way to show what the callipers in that list are, ie, if they're front / rear, Girling / Bendix?
    These are all girling but will check front and rear when I fire up my computer in a bit
    Updated the post, when I get a chance I will write the rears in as well. Just taken a look at the Citroen ZX 1.6 and 1.8 has same front and rear calipers
