Results 1 to 15 of 15
    Jun 2012
    big brake conversion
    hi guys ive bought a RT gt turbo phase 1 any advice on a big brake conversion,would the calipers off a 182 fit, im running 15s,turbines.what are the procuders and what parts do i need,thank you all
    Member clee's Avatar
    Derbyshire
    Re: big brake conversion
    I'm sure there will be other replies but here's a starter
    https://www.rtoc.org/boards/showthread.php?t=26066
    Jun 2012
    cool thanks pal im new to the site
    Moderator
    South East Regional Rep
    LiamR's Avatar
    Dec 1998
    Medway, kent
    I think some caliper extender brackets and renault 21 txi discs are a good upgrade.
    Not done it myself but I am sure someone will correct me if I am wrong.
    Jun 2012
    what about the clio williams upgrade ??any good ???
    Committee Member
    North West Regional Area Rep
    BluntyR5GTT's Avatar
    Nov 2009
    Stoke-on-Trent
    as liam says above this is a good upgrade takes disc size upto 285mm if memory serves me right, makes a big difference
    Jun 2012
    were could i buy this set up from guys, thanks for your advice
    South Wales
    This was the cheapest i found
    https://safe.brakeparts.co.uk/loadnew.html
    £80 and thats for drilled and grooved not plain
    Non-member Ricardo's Avatar
    Put a wanted ad up in the classifieds for the caliper extenders. Tuners used to sell the discs and extenders as a kit not seperately bur someone might have a set knocking about.
    I still have the drawings/dimensions for the extenders and had a batch made in a group buy years ago
    Jun 2012
    Thanks for your help
    Banned
    Apr 2012
    Anyone offered the 172 front brakes up to the 5GTT hub? The 21 TXi discs are a good fit @ 285mm but the hubs are different and hence the calipers are very different fit wise.
    I can't help but note that the front discs (280mm) would fit on a 5/9/11 etc hub, and the actual hub arrangement is pretty much the same as the 5 one. Balljoint, wishbone, track rod, shock etc etc to the point where I wouldn't be surprised if the hub casting was interchangeable as it is between the 5/9/11/19 and so forth.
    Are we missing an easy 280mm brake upgrade here? (I'm too lazy to go outside and try it myself lol, its WET today!!
    Apr 2011
    Netherlands
    It can be done. I have some adaptors lying about to bolt a 172 caliper onto valver/5 etc. Hub....
    Are for sale cause i'm going 4-pot...
    172 discs fit but you still need an extender bracket for the caliper
    Jun 2012
    Cool how much mate?
    I bet the bearings are different between the 172 and GT hub
